Radar Detector Direct Wire - Tap to Swtich Power
My personal preference for radar detector placement is right smack in the middle of the windshield from top to bottom. Just high enough to clear the rear seats when there is an alert coming from behind.
You will notice a lot of people put their radar detectors high up right by the headliner or the sun visors. Keep in mind this will limit laser alerts.
The lower the radar detector the better the laser alerts. Yes I know that typically once you get a laser radar alert it's already too late. That's not always the case, sometimes you do have a chance to slow down without being detected. I personally have multiple dashcam videos on my youtube channel of radar detector saves.
Placing it high up is convenient aesthetically but not best performance. In the middle of the windshield does not look appealing at all but it is for better protection. And lowest to the dashboard limits your 360 detection range but gets you best laser detection. So it does depend on what works for you.
On to the pics-
I like mine right above my dash. It's right next to my fingers to press the buttons and easy to see.
I spent hours trying to connect to the passenger footwell fuse panel via a fuse tap. Connecting to the ground bolt was a pain, and then when I finally got ground, the fuse tap wasn’t working. I finally was about to give up and pay someone (even though I knew it should’ve been an easy install) when I found your post. Beforehand, I didn’t even know there was a 12V plug under the glovebox there… I had never seen it!
Your method took less than 30 min. I already had the wire routed up and around intro the fuse panel compartment, so it was easy to reroute back to under the glovebox. Connected first time and good to go! 🙏🏼🙏🏼
