NOx issue
I just bought a used W213 220D and the car came with the "Check Engine" light on. I made a quick diagnose in a small garage near my town and I got the following error related with a NOx sensor 2 malfunction.
Error code
I want to order the sensor online and replace it but because my car has two NOx sensors I'm not really sure which is the number two.
So at this point I think this is the code for NOx sensor 1
and this is the code associated with NOx 2 (the one I need)
The thing is I'm not 100% sure about this. So, can anyone confirm that my assumption is right?
In case someone else need it the best deal for this NOx sensor I found it here https://www.aliexpress.com/item/A000...888977108.html
Does anyone know what is the part number of NOx sensor 2 (cylinder bank1) for w212 e-class 220 blutec 2015 WDD2120012B198375 ? I have the same error P229F91.
Thank you
I got error P3006 on my W213 220d, Oxygen sensor 2 bank 1, and I am not sure by my research here if I found it correctly, A0009054704 would it be? Thank you!
I found it from the photo of the locations of the sensors above, but I think i might be wrong!
