W213 Retrofitting Full screen LCD - minor issue
First of all my initial setup:
Garmin map pilot, small 8 inch LCD multimedia display
Analog speedometer.
NTG 5 head unit.
What i had to buy
NEW screen(because if you would buy an used screen, you would face the 'dashes' issue: your mileage wouldn't be displayed. There is a workaround, but its costly)*dealer price 2700 euro, I got mine for 1300 euro.
NTG 5.5 Head unit( High Command) Dealer*dealer price 3200 euro, I got mine for 800 euro.
Multimedia Module(Optional, but i wanted apple carplay, so this was a must have) 200 euro
wiring harnass for multimedia module 90 euro
Wire harnass for LCD.. I think it's called the LVDS cable 80 euro
Coding was around 200 euro, but still some things aren't good....
First step is to install the new head unit and wires, it is plug and play. The multimedia module does need a seperate 12V source.
The screen install is peanuts, 3 T20 screws and swap it out.
Coding should be done by someone who knows what they are doing.
It took me several weeks to get it working, but as I said earlier, I have never worked with benz before.
And I dont have C4/Das/Xentry/Vediamo, which I might buy in the near future.
I added a pic of the result.
For now it works, just two minor issues left
First; my backup camera is displayed incorrectly, it has the old resolution, and its super glitchy. parking sensors/parkpilot not working properly anymore
Second; Ambient lighting isnt working yet... But In the light settings menu of the car I cant set brightness level for the cockpit, so my guess is, that is not coded?
Have you fixed the issue?
Could you, please, open it or share it in dm? I would be very thankful.
I have a problem. I purchased a used widescreen and I replaced the audio 20 to widescreen with ntg 5.5.
So everything works fine but I have problem with milage. The display show this.: -------- .
I would like to ask how to add to the used display the original milage?
pleas solution for this problem
Thank you.
Idolvski
First of all thank you @Chris_The_Swede sharing my video..
Mblink is very powerful tool now, and i'm constantly developing Mblink and adding new features.
You can renew your cluster for W213, W217, W222, W205, W447, W470, W204, W117, W177 ann so on..
Please check my youtube channel for other video and how to do with Mblink.
As you see that Mblink has also own Flashing system for IC222 cluster to make AMG menu and 330KM
https://youtu.be/45qE0gL05Ck
Chris
C K M Car Design
I offer solutions!
2,Used screen remote programming fixes like "----" and renew, and more AMG menu activate
3,360 system coding
3,Carplay activate
As the owner said,There's a small problem with the ambience lights.after we code,You can adjust the brightness.But it can't be adjusted to very high brightness
