E-Class (W213) 2016 - 2023
Air conditioning
Old May 17, 2019 | 02:25 PM
mgb64701's Avatar
E300
Air conditioning
I bought my first ever Mercedes last June of 2018, a used 2017 W213 E300 4matic, an executive demo model. The AC worked wonderful last summer. We had our first really hot day here yesterday (92 F), and it took at least 6 minutes to get to a comfortable temperature in my car. It seems to me it was working better last summer. I was wondering how long it took some of you to get your W213 to a comfortable temperature with the AC.
Old May 17, 2019 | 05:55 PM
ua549's Avatar
My E300 w/acoustic comfort package only takes a couple of minutes to cool the interior. Temps and humidity ave been in the 90's for a couple of months. I typically remote start the vehicle to cool it down before entering.
Old May 17, 2019 | 06:21 PM
Lanzz's Avatar
2024 E450 AT Wagon, 2024 EQS450+ / Had: 2021 E350, 2019 E300, 2021 + 20 GLE350, 2019 E450 Wagon(s)
My 2017 E300 takes forever to cool down on a hot day. Today was over 90 degrees, and when I came out of the office, the car was an oven, which it remained for most of the 30 minute drive home. I don't think the AC capacity is adequate for the car - and the dealer says the AC is working as designed.
Old May 17, 2019 | 06:31 PM
ua549's Avatar
If I can't pre-cool the car I always open the sunroof and windows for a minute or two while moving to circulate the air. Then I close the car and set the air on recirculate. It never takes longer than 5 minutes to cool to comfortable levels.
Old May 18, 2019 | 04:26 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Good one.
The AC in all my MBs has worked great. The only thing I ever noticed was that my GLE400 revved up the motor more when it was really hot. But I do think some of these smaller motors now a days have more trouble trying to keep the AC running and cooling everything well enough.
Old May 19, 2019 | 11:32 AM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Living in sultry, steamy Florida, the A/C in our E400 and E450 cools the car in just a couple minutes and stays comfortable through long and short journeys. I see nothing inadequate with the cooling system.
Old May 19, 2019 | 01:14 PM
joshg1001's Avatar
2017 E300
so many variables, such as what color your interior is, and whether you parked in the sun or not. I think MB AC has never been its strong suit.
Old May 19, 2019 | 01:16 PM
rbrylaw's Avatar
My E450 is Lunar Blue (dark), with brown leather (pretty dark) and even if started after sitting in the sun for hours, it cools quickly. I've never felt MB A/C wasn't a strong suit, tbh.
Old May 19, 2019 | 09:37 PM
Lanzz's Avatar
You guys are convincing me that I need to hit the dealer and have mine checked - it's barely cool after a half hour of running at full blast...
Old May 19, 2019 | 09:59 PM
Almashayekhi1's Avatar
C200
Definitely check the dealer. Half an hour is about 28 min too long. It should not take that long at all.
Old May 19, 2019 | 10:00 PM
rbrylaw's Avatar
That's not right. Get it checked out.
Old May 20, 2019 | 02:55 AM
JDPEClassUK's Avatar
E Class Estate S213
At least have the refrigerant and pressure tested - and temp at vents then you will know if it the car or not.
Old May 20, 2019 | 03:56 AM
CaptainE's Avatar
2019 E450 sedan
Not good, get it checked out. Mine is quite chilly, in Phoenix.
Old May 20, 2019 | 09:25 PM
mister__p's Avatar
E250
Where I live it can reaches 39 Deg C in the summer and the car can sometimes shows 47+ deg C on the dash after sitting in the sun a while but it cools down fairly quickly once the air con is on. Within 5 mins, the air is cooled so I can breath normally but the dash and trim can take another 15 to 20 mins to cool from being burning hot if the sun is still shining.
Compared to my previous Audi, the MB air con is slightly weaker but certainly not an issue.
If you car is not new, make sure you have all your filter(s) checked as dirty filters will lower the performance of the air con. Even a 5 to 10% loss in air flow will result in much less cooling.
Old May 20, 2019 | 11:19 PM
jhpmbusa's Avatar
2021 M550i
Same here, prior to all my other MBs my E300 does not really have a strong AC unit. Not sure if its the temperature or the power of it but I gotta get it to fan speed 6 or 7 to get things going. I think there was another post about this as well.
Old May 21, 2019 | 08:49 AM
nycebo's Avatar
2021 Mercedes Benz e450 Wagon
For my part, the air conditioning works reasonably well. However, what peeves me is that the temperature always needs to be adjusted. In the older model, I would put the car on 72 F and Auto and it would just always take me to that temp. Now, I have to move the temp setting around a lot in order to get comfortable.
Old May 21, 2019 | 09:35 AM
CaptainE's Avatar
2019 E450 sedan
What peeves me is that I have to select recirc each time I get back in. Why can’t it keep the same settings it had when I shut the car off?
Old May 21, 2019 | 04:12 PM
Yeap! It would be nice if all the settings went back to where you left them.
Let's all be thankful too that we don't have the BMW G30 A/C. (Go read those reviews)
Old May 22, 2019 | 01:46 AM
madtrader's Avatar
2019 E450 Wagon
I’ve noticed this as well. I basically never touched the setting in my w212. By 2018 e400 wagon was black with a panorama roof and the A/C definitely worked harder than in my 2019 e450 wagon which is white, no panorama roof, and has the acoustic comfort package, but still not as well self-managed as my w212.
+1
Old May 28, 2019 | 05:50 PM
Aram.94's Avatar
W213 E43 AMG
check your cabin air filter. either clean it or just change it. if its old and dirty it can effect you AC system.
Old May 28, 2019 | 06:38 PM
2012 merc amg's Avatar
2018 S560
I'll never forget my old Cadillacs with the R12 Freon A/C systems, those would cool down in 30 seconds or so, but I'd say the Benz is adequate, not great, but like 5 or 6 minutes to cool down on a hot day.
Old May 30, 2019 | 09:30 PM
baadmon's Avatar
2020 MB GLE 350
Now that the season has changed, I tend to use my A/C more frequently. I dread using it as the smell from the cabin filters makes me extremely nauseous. I contacted my service advisor and she advised me to allow the A/C to run a little to negate the strength of the fumes. Unfortunately, that didn't work and each time that I cut on the A/C that smell has me gagging.
Old May 31, 2019 | 07:33 AM
ua549's Avatar
There may be mold/mildew in the vents from disuse. Try spraying a disinfectant such as Lysol into the air intake with the fan blower running at full speed.
Old Apr 24, 2020 | 07:01 AM
baadmon's Avatar
2020 MB GLE 350
Does anyone notice a foul odor embedded with the air that comes though the vents. I have mentioned this to the dealer and they advised to leave the AC running a little while after I reach home.
I haven't tried that, but don't believe that's the issue. Not to mention I am on my third Benz and all of them have possessed this same odor coming from the AC.
Old May 5, 2021 | 10:00 AM
AlisonAlsop's Avatar
Jane
Hello everybody! To be honest, it seems to me that you have not fully understood the principles of the car's climate system. All parts have a habit of wearing out and the air duct is also directly related to this. Therefore, the climate system filters must be changed at least once a year. Otherwise, a lot of dirt gets clogged in them and they hardly let air into the car. If you do not change the filters on time, then sooner or later you will have to turn to the repair and cleaning of the air ducts. I hope I helped you with information and you draw the appropriate conclusions. Good luck to you!
