E-Class (W213) 2016 - 2023
2017 E300 4MATIC GAS/FUMES SMELL
Old Dec 10, 2020 | 09:23 AM
TPAbnz's Avatar
2017 E300W
Any idea on cost to replace low pressure fuel line?
Old Feb 3, 2021 | 06:16 PM
FlynnMobile's Avatar
2017 E300 AWD
Replacement of the two flexible fuel feed lines
Originally Posted by Petmerctech
Have your dealer replace the two flexible fuel lines from the fuel feed line to the high pressure fuel pump.There is no official bulletin on this but this is the fix.
We had the same experience today. Two fuel lines being replaced and car will be back to us tomorrow, so I hope the gas smell goes away.
Old Feb 3, 2021 | 10:50 PM
2012 merc amg's Avatar
2018 S560
I would think those lines would be under the rear seat and remove the access panel that covers the fuel pump? Is this correct? I have a S class and it does this same thing. I may only have to have the passenger side of the rear seat cushion pulled up as I have rear bucket seats with the rear seat package and built in center console. I have the exact same symptoms as was outlined in the above post, it's been driving me nuts trying to figure out what the issue was. i've had it to the dealer 3 times now and they found nothing like usual. It is mainly first thing in the morning that I notice it after I open the drivers door. Maybe the fuel pump is activated when the door is opened as I do hear some sort of pump come on towards the backside of the car and then I get the strong gasoline smell.
Old Feb 4, 2021 | 05:36 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
Originally Posted by RickM2
I am going to take it back to the dealership again.
I can’t believe how casual this seems to you folks. A gas smell is dangerous. You all sound like it’s a minor inconvenience. It’s dangerous.
Old Feb 4, 2021 | 08:19 PM
2018 S560
It's not like the underside of the car is coated with gasoline or anything, it is bone dry under the car leaves no drops or anything like that. It must just be a slight seepage. I've complained about mine 3 times now to dealer and each time they cant find anything they say so what can one do? I do plan on trying another dealer the next time the car is serviced and mentioning it again. I do not believe it is a fire hazard, just an annoyance.
Old Nov 9, 2021 | 04:52 PM
goppalrg's Avatar
Mercedes S560. 2018 model
Every time I get in the car I smell gas. Sometimes after I open the front door and before I start the car. I purchased the car recently and it's still under warranty. The dealer tells me they don't smell anything. I have had other people in the car who also could smell the gas. Is there anyone who has had a similar experience?
I have the same problem . gasoline smell inside the cabin when I stat car and around the car when I enter garage. Took the car to dealer for checking. He says no leaks found. Still the same and more last couple of days. taking back to the dealer again tomorrow.
Old Nov 10, 2021 | 12:22 AM
  #32
norken's Avatar
2017 e300
Smile Fuel smell
I got this kind of problem before. This is how the dealer fix the problem on 13Jun19. No more gas smell since.
Old May 5, 2022 | 02:15 PM
  #33
ptheodoropoulos's Avatar
2018 Mercedes E43 AMG
2017 E300 High Pressure Fuel Pump Leak
The second stage high pressure fuel pump that is located inside the engine compartment on top of the engine and towards the firewall is leaking gas from the seals causing a distinct smell of fuel in the car and creating a fire hazard. I cannot believe this!!!! TOTALY UNACCEPTABLE.
Old Nov 19, 2022 | 03:03 PM
  #34
VivaLaV's Avatar
2017 Mercedes Benz E300
Re: 2017 E300 MB
I have the same issue. No one seems to know why it smells like a strong gasoline. It’s only when my
vehicle sits in the garage for a long period of time. I have a washer/dryer that’s right next to my car and every time I do laundry, I smell it! I’ve taken it to 2 mechanics and they’ve told me they don’t see any leaks, but I smell the strong smell of gas! Had anyone had any luck on finding out what the problem is???
I will NEVER own another Mercedes Benz again… EVER!
I bought it brand new, and I am just disgusted that it has such a dangerous issue and it’s only 5 years old!
Old Nov 19, 2022 | 03:14 PM
  #35
VivaLaV's Avatar
Originally Posted by magicve17
Check my reply to other guys. I solved the issue at dealer. My dealer said it was kind of common on C class but rarely found on E class
WHATS THE FIX GUYS??? My 2017 E300 is no longer under warranty! I am just disgusted w MB. I
will NEVER purchase this type of crap car again! Expensive, but made with dollar store parts! Please let me know what the FIX was! Thank you!
Old Nov 20, 2022 | 08:12 AM
  #36
The G Man's Avatar
2019 E300
when you fill your gas, do you like to top off after the pump has stop?
Old Jan 4, 2023 | 01:53 PM
  #37
GPF's Avatar
GPF
2018 S450 4-matic W222
I had the same gas smell, specifically on startup and worse on cold days. I had it checked at MB Augusta, GA the day after Christmas since we were out of town for a visit with family.
They verified that it was 3 fuel lines leaking in the engine compartment, two of which were covered under an extended warranty from MB. The only one I had to pay for was the cheapest fix. No fuel smell at all after that.
Old Jan 10, 2023 | 09:50 PM
  #38
Ajamer's Avatar
2017 E300
Gas smell
1)I just wanna ask does anyone associate the “gas” with like WD-40 type smell ? Just wanna be sure I’m smelling the same thing or I’m just smelling gas. Overall I’m having the same symptoms as everyone else.
2) has anyone been able to get an estimate on the fix outside of warranty please? Thanks in advance
Old Jan 10, 2023 | 10:03 PM
  #39
2018 S560
I really think it has a lot to do with the type of clamps they use from the factory. Put a new clamp on my low pressure fuel line and the issue was solved. It was under the hood on the right side over the right passenger valve cover. This was on a S560 2018.
Old Jan 11, 2023 | 12:07 PM
  #40
Ajamer's Avatar
2017 E300
Thanks for that. I’m having the same issues as everyone else 😆
1- go to shop to complain about a gas smell
2- they reply there’s no smell (it’s gone by the time I’m there)
3- they check all the fuel lines and 100% assure me there fine and to come back if it continues
I didn’t want to insult my mechanics intelligence so I’ll go back in a few days. But the clamps you mentioned that’s the first time I hear about it and could be a simple fix will update once it’s resolved 🙏🏻
Old Jan 11, 2023 | 12:32 PM
  #41
2018 S560
All it takes is a tiny bit of seepage where the metal meets the rubber fuel line to give of a strong odor at certain times. Take a finger and go around each joined fuel line area and see if you come up with any gasoline smell on your finger. Seems like especially the low pressure fuel lines are having issues where the rubber line meets the metal line not real crazy about the design of these factory clamps I don’t think they clamp off the rubber line tight enough.
