"B"Service Results
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Do not worry!
I now have close to 6,000 miles on my E450 with RF Pirelli Centurato P7: the ride is silky smooth and I anticipate minimum of 30,000 miles. I do not accelerate hard from stop signs, do not brake hard but anticipate stopping by slowing down but do drive above 70 mph on the Interstate. My driving is 50% local on Long Island and part in NYC, the other 50% on the interstate. I have an excellent air compressor at home and religiously check the pressure to make sure it is 10% above the recommended pressure as per the fuel tank flap: 36 psi front and back.
I have no intention of swapping out my tires for any of the deficiencies mentioned by many of the posters here simply because I have not experienced any of those deficiencies.
But then again, I may not be as finicky or have the sensitivity that other poster here in this forum have
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 1,751 Likes
2016 E350 Sport
It is not uncommon for OEM tires to be a softer compound from high-end manufacturers such as Pirelli, Michelin, Continental. I've since abandoned considering the repurchase of OEM and rigorously researched crowd-sourced reviews, i.e. Tire Rack. Save yourself a few bucks and look into Kumho or any other brand aside from OEM.
Last few years, I've had much better longevity from Yokohama tires. And frankly, the OEM Kumho tires on the wife's Hyundai Sonata have passed 30,000 miles and have another 5K left.
ANY tire can be made to ride comfortably by properly designing the suspension. A solid rubber tire would work (comfort only I'm talking about), if the suspension were extra cushy, and more rubber isolation, etc. Mercedes has made the decision to eliminate the spare, which a LOT of manufacturers are doing, and have gone to run-flats to minimize the disruption when/if you have a flat. I think that decision makes sense. Having decided that, I think the Engineering department at MB is smart enough to design a suspension that works well with them. And again, IMHO, they have.
Now, if you believe all that (I do, you may not), then putting non-run-flat tires on the car should absolutely change the ride and handling characteristics of it. Just like going to softer springs. Well, I don't see any threads here with people replacing their springs. And if there are any, it will be to make them stiffer, not softer. We all know that too soft of spring may ride great, but give up handing. And I think softer, non-runflat tires might do just that as well.
I find the overall ride pretty fine for bigger shocks, road dips, float, etc. It's the road imperfections/isolation with RFT's I mind- chatter, patch lines, etc that a good tire deals with quite well. And there's just much more of that than bigger bumps, etc. I'm very much looking forward to throwing my NRFT winters back on in a few weeks's time. Then maybe next summer I'll feel like I've used up the OEM RFT's enough to swap them out too.
I'd probably be most happy with a super stiff anti-roll suspension and soft tires. Maybe I need an indy car.
Other than that, I agree with what you said.
