E-Class (W213) 2016 - 2023
Trunk does not open
Old Nov 21, 2019 | 02:23 AM
tronics's Avatar
w213
Trunk does not open
Hello guys,
I hope you all are doing good. The trunk does not open neither by the trunk handle nor with the door button on the driver's side. The only way to open trunk is with the mechanical blade. To make it more interesting, we can also open the trunk with the Mercedes diagnostic tool (Xentry) when we test/activate the trunk lock actuator. Do you experience like this? What might the problem be?
Any advice will be appreciated.
Old Nov 21, 2019 | 09:12 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Check the valet switch in the glove compartment. It is on the left side of the glove compartment If this switch is activated many functions opening the trunk are not available.
Old Nov 23, 2019 | 02:48 AM
tronics's Avatar
w213
Thank you very much. I will check.
Old Nov 23, 2019 | 03:30 AM
tronics's Avatar
w213
THANK YOU VERY MUCH. It was that switch. Thanks a lot.
Old Dec 17, 2021 | 09:06 AM
Another Car's Avatar
SL 550
As a last resort I sprayed some WD40 in the latch. Shouldn't hurt. I also ordered a manual, CDs. Hope that will get me some info.
