E-Class (W213) 2016 - 2023
W213, Jerk/jolt on change down 3rd to 2nd
Old Nov 23, 2019 | 04:10 PM
Donaldoo's Avatar
E220d 2016 W213
Hi, I’m new here. I’ve recently purchased a 2016 e220d W213. There is a noticibale jolt from 3rd to 2nd. It only happens about 5-10% of the time and in all drive modes. I’ve had it in with Mercedes twice. The first time they say they found a fault on the active brake system and reset it. This didn’t fix it. The second time they did a software update on the gearbox. It still isn’t fixed. It’s difficult for MB to know if it’s fixed as it doesn’t happen all the time as in a test drive. Has anyone here experienced this and is there a solution. Car is spot on other than this which is just an annoyance. Mileage is 35k.
Old Nov 24, 2019 | 08:25 PM
mobster600's Avatar
e300
When does it happen? The transmission downshifts during braking 100% of the time. I get smoother downshifts when I’m slowing from higher speeds and a bit more noticeable downshifts during slower speeds.
And the 3rd to 2nd is the most noticeable. I can’t say it’s a jolt, it’s not bad for me.
Old Nov 25, 2019 | 02:21 PM
Donaldoo's Avatar
E220d 2016 W213
90% of the time it changes down perfectly, it doesn’t matter if I brake hard or easy. The jolt, which can be like standing hard on the brake for a split second, happens randomly
Old Nov 25, 2019 | 02:30 PM
mobster600's Avatar
e300
Ok so it’s the brakes not the transmission. Do you have the active lane assist package? Owners have had their brakes warped and prematurely worn because the system brakes constantly.
Take it back to the dealer they will have to open a ticket with MB Germany. Have the engineers diagnose it
Old Jan 8, 2022 | 04:20 AM
mshanker's Avatar
E350e
Is the issue now resolved? What was the diagnosis? I have same issue where the car does sudden jerk at lower gear, I think once in a while. It drive smooth and without issues most of the time.
Old Mar 21, 2022 | 05:53 AM
MarcoAntonio's Avatar
Mercedes E220d W213
Hello. Same problem here, have you guys solved it?
Old Mar 21, 2022 | 05:55 AM
Mercedes E220d W213
hello. Have you solved this problem? I got the same one
