Where are your rattles coming from ?
I have those inserts (felt taped on both sides), along with some stickers on the b-pillar (the metal bit next to the rubber seals) that press the door trim when closed to further help the trim to remain in its place. The stickers are two layers of electrician tapes (as they don't leave any marks) and two layers of felt tapes sandwiched in between. If you want to DIY you should be prepared to experiment a lot to find the combination that eliminates the noises.
that the quality of materials and craftsmanship is declining. I would not allow the dealership to take the door panel out for fear that the noise(s) would probably be worse and or the door panel may not be aligned properly.
For the door handle and the surrounding area (mainly the window switches) noises, are you referring to the plasticky squeaks? The technician at my dealership agreed that it was utterly rubbish and did some work to improve that, by a huge margin. Hopefully you can find someone that you trust enough to open up the car to fix these things.
Unfortunately I think this is just lazy designs rather than poor materials or craftsmanship: the cars are built exactly as they were designed, maddening squeaks all round. Right now I'll take an ugly audi over mercs or bmws any day.
The noise seems to come out when the suspension moves up and down.
Looked in the back for a lose panel, or whatever could cause it, nothing..
Will have my car mechanic buddy lay down in back to help identify the source in a day or two,
Anybody else with a similar noise from the right rear on a W213 Wagon?
That being said I DID just come across TSB LI32.25-P-066246 in the wonderful recall/tsb thread. I’d go armed with that and see if that helps! Keep me updated.
Thx
1 slight rattle coming from the front right behind the dash, associated with acceleration / engine torque. checked under the bonnet for anything possible there, used some cable ties but to no avail.
2 centre dashboard creaking - cured this by taking off the big speaker cover, putting grease on the tabs connecting the two plastic pices, and lined it with speaker cloth - problem solved.
3 car was on 20" rims with 30 profile run flat tyres, absolutely undriveable on Irish roads, got fed up with the fear of hitting even a slight pothole and changed them all for normal tyres - absolutely transformed the car into a proper Merc.
4 Most seriously, there is a harmonic / rhythmic juddering about 120-130 KMH ( 70-80 MPH), this is with new tyres properly balanced and inflated - also associated with brake judder. I mentioned this on the last service and got the usual blah blah about warped discs; when I asked what the run-out was on the discs I got an "Oh S@&£ this guy actually knows something about engineering" vacant look. What concerns me from reading other posts is that this is a possible drivetrain issue; either a diff problem or a driveshaft out of balance, just wish MB would come clean with an answer instead of reading from the workshop manual. Im not sure how they would be warped when i dont exactly drive it like a racecar.
5 lately it has developed a rattle in the passenger seat headrest, i have opened up the seat and checked the body of the seat for rattles but it is solid, curiously it is not noticable when someone is in the seat, drives me crazy when driving it to work though..
I expected better from my first Merc, I had driven 4 VW Passat's as company cars for over 12 years with no rattle issues or issues with brakes etc.
Can anyone confirm if, with the car on, they hear a little air pump and release when you apply/release their brakes? None of my other cars do, but I noticed it on my Benz and wasn’t sure if it’s normal for MB to do this (it’s my first one!)
Rattle noise area during bumpier roads
I can stop it by pressing inward in this area
Did the test ride with a service advisor, he did not hear anything out of the ordinary.
I tried various speeds and roads, but today the noise was not very pronounced, although I could clearly hear it.
I asked the SA if his ears was ok?
He replied his ears are fine, and also said he used to be a tech and he knew his stuff, there was nothing wrong with
my car and something has to be broken for them to fix it,
I got a bit ticked off, but had no case: Of course the problem must be duplicated. (There was no speed bumps in the area around the dealer)
I gave up and dropped him off.
Not sure what to do next..
Find speed bumps and video record the noise repeatedly? Go to a different dealer, or find an Indy shop?
Wait 6 months and see if the problem gets worse?
