Fuse diagram for 2021 all-terrain
2021 e All Terrain, 2001 e55
In the foot well on the passenger side of my car is a fuse box under a cover. I want to install a dash cam but I don't want to utilize a fuse that is connected to something important. Does anybody know where I can get a diagram for that fuse box? Eventually I will find it and post it.
Phil
Phil
Received 4,435 Likes
'71 Pinto
See if this works.
E 300 AMG-Line diesel-Hybrid - 2021
i'm sort having a similar issue.
i've always hooked my dashcams on the 2 cigarette socket fuses at 15 amps
but it seems the new cars don't have these anymore and i take it the usb ports are only at 5 amps ?
Thank you very much for this. I'm trying to find a fuse that isn't connected to something important and is only active when the car is turned on. I don't know whether the spare means that the fuse is active or not. I also don't know if I will have a few slot for an option I don't have. I have almost every one of these options except the perfume.
For sure this will help me thank you very much
phil
phil
I have read your posts. You know a lot. I will install mine next week and make photos. If I can do it anybody can. I bought from Blackbox my car and read about BlackVue on Vortex.
Egonvdv (12-18-2021)
I seldom drive my car because I live in Manhattan and walk to work. Last night I went to the garage and looked in the trunk and there was a diagram with all of the fuses and what they are for. I'll try to scan it and post it if I can figure out how.
There is also a cigarette lighter adapter in the back of the car and I'm going to use that to plug in the eight cell battery I bought and then plug the dash cam into the eight cell battery. I'm having a little bit of a challenge because I'm reluctant to take the liftgate apart so I'm probably going to let a wire for the rear camera hang down even though that looks a little bush league.
I will post photos. thanks phil
'71 Pinto
Here's what I have on hand.
Bfgslkman (12-22-2021)
Turns out my car DOES have 2 cigarette plugs, so will use those again.
Have not looked at the actual fuse diagram in my car yet, but it must be different
from what Konig posted here above (as that one show only 1 cigarette plug)
I just did it too :-)
PAGE 1: https://www.dropbox.com/s/zplhpa7wtw...e%201.pdf?dl=0
PAGE 2 https://www.dropbox.com/s/m4nzcru763...e%202.pdf?dl=0
Fuses 457 + 458 (15amps) are what i always use for the dashcams
So konigstiger's diagram is actually correct, just different wording about what each fuse does
e55phil (12-22-2021)
This is very nice On the back is a list of what the fuses are used for. Can you upload that also? PS: I am impressed you got th entire page!
