E-Class (W213) 2016 - 2023
Plz Help me lift my whip
Old Feb 23, 2021 | 07:27 PM
UYD4LYFE's Avatar
2018 E400 Wagon
2018 e400 wagon non airmatic amg sport package. I absolutely love this car however as of late I’m frequenting some unpaved dirt roads semi maintained but lots of dips and bumps and I’m bottoming out too often and I just need to find a way to raise this car slightly. Strut shim ? Lift kit anyone ?? I would only need want like an extra inch or so and then get a bit more with a larger sidewall all terrain tire. Think bougie outback. I know the all terrain is here or will be shortly but I can’t justify swapping this car at a loss for that. Also it would seem as airmatic is standard for the 2021s that I wouldn’t be able to change my oem components for the new ones and solve the problem. I would truly appreciate any insight or thoughts on someone to help even fabricate a lift kit for me.
Old Feb 24, 2021 | 12:54 AM
ItalianJoe1's Avatar
2003 CL 600
Short of using a spacer above the strut and spring mountings, your best bet is a swap to a different car. This is not the type of modification you want to be doing on a car with suspension this complex. Even if you get it to work ok, you will badly shorten the working life of the rest of the multilink components running them above design angles for extended periods of time. That's why airmatic will lower back down automatically at speed.
Old Feb 24, 2021 | 02:57 AM
UYD4LYFE's Avatar
2018 E400 Wagon
so would the same logic then be true with the added stress and life shortening in the reverse with say, after market coil overs or lowering modules that seem to be popular ?. I wasn’t aware that the system was so complex without the airmatic. I thank you for the reply and insight.
Old Feb 24, 2021 | 11:53 AM
The_Judge's Avatar
2018 E400 Coupe
Lift your whip? Pardon my ignorance, but what exactly is the "whip" on a car?
Old Feb 24, 2021 | 12:12 PM
UYD4LYFE's Avatar
2018 E400 Wagon
lol I apologize. Whip means car.
Old Feb 24, 2021 | 12:15 PM
The_Judge's Avatar
2018 E400 Coupe
Ah! Live and learn. Thanks.
Old Feb 24, 2021 | 12:51 PM
DFWdude's Avatar
2016 E350 Sport
How refreshing. Someone wants to raise the car rather than lower it. Who'd a thunk it?
Old Feb 24, 2021 | 01:20 PM
ua549's Avatar
As the years go by it will become an adult, if he can raise it.
Old Feb 24, 2021 | 03:50 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
In what regional dialect? The region of autoco-wreck?
Old Feb 24, 2021 | 04:49 PM
ua549's Avatar
A whip has simply come to represent a car. It has been said that it was used a long time ago when a whip would be used to steer the horse-drawn carriages. It is used in hip-hop fashion, and it has come to represent any car not necessarily a really nice car.
Old Feb 24, 2021 | 10:30 PM
2003 CL 600
Yes, lowering a car does the same thing in the other direction.
