seeking for help - steering malfuction
Anyone has this exp that the light on - Steering Malfunction.
This car only run 14000km, and checked by original service...
Now they say need to change the power steering. very costly. Any other suggestion? Thanks for help and advise first~
this light suddenly on
Busy dealer can look up your eligibility over the telephone 🤞
Visually check electrical connection/harness to steering gear if fine, you may need to replace internal motor or gear assembly but before proceeding have someone pull/clear fault codes. If motor or gear is faulty replacement may involve high voltage procedures & alignment for your vehicle. Note MB does not offer motor separately you will need to identify and search for replacement or search for used steering gear here are gear compatible part #s:
