E-Class (W213) 2016 - 2023
L.E.M 3" 200 Cell High flow Catted Downpipes for the E400/E43
Old Aug 4, 2021 | 10:22 PM
EbonyCoupe43's Avatar
C43 Coupe
We want to introduce our downpipes for the W213 V6 twin turbo platform for the E-Class. For those who want to take it to the next level and give their E a stage 2 boost with either a JB4 or ECU tune we are proud to present our "Monster" series 200 cell high flow catted downpipes. Reverse engineered from the OEM part for 100% bolt on plug and play installation with a deep refined guttural sound worthy of a German q-ship. We have sold plenty of these for the C, and those who are performance oriented for the E can take advantage of the cross platform fitment.
THESE CAN BE PURCHASED HERE:>>
https://www.logosengineeringmotorworks.com/mercedes-amg
Construction:
  • Redesigned with 3" piping and a larger body
  • Deeper throaty sound with 15% more flow than our standard pipes
  • Entire Down Pipe is constructed out of rust resistant T304 SS for durability
  • Original Stock Downpipe is 3D scanned and reverse engineered for perfect direct bolt on fitment
  • Thick 8.5mm welds to prevent leaks or cracking
  • Argon gas back purged welds for penetration and seal =Long life
  • CNC T304 flanges, with connection directly to the Turbo outlet V-band
  • The only downpipe on the market that mimics the OEM design!! has sensor inside the catalyst, like original
  • 200 Cell high quality triangle matrix honey comb catalyst flows better than stock and competitors
  • Fully TIG welded construction, beautiful welds that can be seen!
  • Plug and play, no modifications needed,100% perfect fitment
  • Includes all hardware and bolts for installation
    Performance:
  • Get rid of that nasty smell that you get with catless downpipes and that awful "rasp" that come with de-cat pipes. Unleash a deeper, refined rumble: This is primarily due to the fact that engine pulse waves can expand in the barrel of the main catalyst body providing
  • Near identical performance to de-cat Downpipes, along with a throaty sound and without the smelly fumes.
  • turbo spools up quicker for better throttle response and unleashes up to 20 HP and 20 TQ
  • Quicker spool allows the power to come in earlier with being able to hold it longer
  • can allow you to go stage 2 on a tune to allow up to 30-40 more HP and Torque
  • re-map using JB4 data log and take advantage of the higher flow for that push you back into your seat thrust around 2500 rpm
  • Over engineered construction for years of use
