E-Class (W213) 2016 - 2023
2019 e450 driver cluster is out, any advice
Old Sep 12, 2021 | 02:42 PM
linjon11's Avatar
2019 e 450
hi. My 2019 e450 driver side Panel is black. I have an appt 9/22, but does anyone have any experience with this.During the ida deluge it sat in a back yard driveway, so I don't think it should have water damage.
Old Sep 12, 2021 | 05:22 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Press the button on the right side of the center console: That is the on/off switch.
Old Sep 12, 2021 | 08:01 PM
linjon11's Avatar
2019 e 450
I have to go outside and check, but I think that turns off the infotainment section
I'm talking about speedometer and oither gauges. I wouldn;t think it would be legal to drive a car with no speedometer
Old Sep 12, 2021 | 08:17 PM
W205C43PFL's Avatar
In that case, try holding the power button to see if the car does a hard restart. Computers glitches now and then and usually a reset or restart is what fixes it.
Old Sep 13, 2021 | 07:00 PM
linjon11's Avatar
2019 e 450
ok. What /where is the power button.
On a side note, my gauges are out along with any potential warnings?.
If I drive with no gauges..idk, seems risky
I may have it towed
anyone go through this?
thanks
Old Sep 13, 2021 | 07:09 PM
JTK44's Avatar
I may have it towed
thanks
I believe the button is on the right side of the center console.
Old Sep 13, 2021 | 09:04 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
You said in that post #2. Post #3 stated that that doesn’t turn on the speedometer.
Old Sep 13, 2021 | 11:11 PM
linjon11's Avatar
2019 e 450
ya, I saw a different video where it had a button on the right side of the center console turning off the radio/nav[, but the buttons on the right side of mine don't do much, not even turn off the infotainment screen.
Old Sep 14, 2021 | 08:16 AM
W205C43PFL's Avatar
Depends on the options you have on your vehicle, the button might be located in the volume control knob which pressing on it will turn off the infotainment screen. This is because if you have certain options, a new button occupies the power button's space.
Old Sep 14, 2021 | 09:55 AM
On my car, all the volume control knob does is control the volume. Pressing it mutes the infotainment system.
Old Sep 14, 2021 | 10:25 AM
W205C43PFL's Avatar
Makes sense if you have the power button but for certain equipped vehicles, that volume control doubles as a screen off button (it will have the power button icon labeled beside the volume icon) because a spot was taken by another feature (especially AMG models for example that has the performance exhaust occupying the space) or other highly equipped cars with tons of options like sunshade, air suspension etc.
Old Sep 14, 2021 | 10:46 AM
I see, sort of like the distronic. No Distronic, separate on and off buttons for CC. Distronic, one button for on/off.
Old Sep 14, 2021 | 02:27 PM
W205C43PFL's Avatar
Yup you got it!
Old Sep 15, 2021 | 07:46 AM
linjon11's Avatar
2019 e 450
Do you think it's safe to drive to dealer, ie no alarms.and what not
Old Sep 15, 2021 | 01:03 PM
W205C43PFL's Avatar
I honestly wouldn't recommend it, you can't tell if your signals are on. (Maybe the ticking sound will still be on), you can't see if your safety systems are active, you don't know what speed you are going, thankfully you can still control your climate control I think because of the existence of buttons still. The worse is you don't know if your transmission is set to drive, park or reverse.
Old Sep 15, 2021 | 01:52 PM
JTK44's Avatar
Depends on far the dealer is: If it is on secondary roads I would do it: Just have a friend (or your wife) go in front of you, have him put on his four way flashers, you too and follow him to the dealership.
I do not think there is much chance of being in reverse if you think you are in forward. As to speed, just use your iPhone on WAZE.
Of course having it flat bedded is safer: Where I live the minimum would be $150 and my dealer is only 5 miles so I would drive.
Just my $.02
Old Sep 15, 2021 | 03:09 PM
W205C43PFL's Avatar
Just my $.02
Sounds like a plan, I forgot to account for the distance OP to the nearest dealership.
Old Sep 16, 2021 | 08:51 AM
linjon's Avatar
nissan maxima
Well, I called the dealer and they said since it's warranty covered they would send a tow truck.
So that's good
We will see what they find
thanks for all the help
Old Sep 21, 2021 | 12:33 PM
linjon11's Avatar
2019 e 450
I heard from dealer. The passenger side carpet was wet and there were "buckets of water" in the ?floor of the chassis.
I never noticed because I rarely have a passenger.
I asked if he thought it might be Ida related, but he said no, that this car has a drain issue.
jeesh..
He said he didn't need any money so far..
