Front multibeam w213 lamps
Hello. What are the types of multibeam lamp for w213? I have the e53 2020year (old model) and I want lamps with a blue dimmer. What kind of lamps should I look for? My car is an EU vehicle.
WDD2130611A663281
WDD2130611A663281
Received 4,446 Likes
'71 Pinto
Not seeing any OE available in MBUSA data base, here are associated codes of current lamp unit to compare for any recommendations that 'may' follow.
Hmm, it didn't help me too much ... So there are two types of multibeam lamps ?? And how to visually recognize the lamp with the blue dimmer? I use the parts catalog: https://www.ilcats.ru/mercedes/
but he shows me too many models of lamps ...
'71 Pinto
Attached part list for 213.061 search for yourself keeping in mind original lamp codes must match for replacement to be compatible. 2139069504 & 2139069604 "may" work but code 809 (shown above and listed in your data card) is missing, your call.
lamps w213
Hello again Thanks for your interest. The problem is even bigger I bought the E53 from the USA and it is with me in Europe. I gave the car vin Europe because I buy European lamps. Can I add lamps with blue dimmer? My car has a damaged front so I want to put on good lamps. This is my number: w1kzf6. What lamps have blue dimming because that's what I want to have here.
'71 Pinto
The part #s in post 4 but no guarantee. I suggest speaking with a local MB dealership parts department for confirmation.
lamps
Thanks for your help my friend
I did the search myself in a different way. I found a couple of e63 amg 2018-2020 richly equipped. I entered their vin. Later the lamp category. Each of them has in the description: Anzeigenummer Teilenummer Beschreibung Vfgb. * Listenpreis
10 A 213 906 27 06
LEUCHTEINHEIT - Ohne blaue Akzente, links
€ 2.646.35
10 A 213 906 28 06
LEUCHTEINHEIT - Ohne blaue Akzente, rechts
And from what I can see, from 2018 there is no blue one.
A2139069508kz (no blue)
A2139062706 (no blue)
10 A 213 906 27 06
€ 2.646.35
10 A 213 906 28 06
10 A 213 906 27 06
€ 2.646.35
10 A 213 906 28 06
10 A 213 906 27 06
€ 2.646.35
10 A 213 906 28 06
lamp
From my investigations, the conclusion is that there are different lamps as of 2018. from 2016 to 2018 there are different. I wrote down many models of e53, e63s and each of them shows "without" a blue accent. I guess it's different in Europe, hmm?
