E-Class (W213) 2016 - 2023
Internal light problem
Old Nov 5, 2021 | 01:56 PM
velryba's Avatar
E220d
E220d 2016
When I turn the internal light on, the strip with LEDs starts to power up, goes to a max brightness and then turns off.
Only lights in the rear view mirror stays on.
Any idea what is the cause and a fix?
Old Nov 7, 2021 | 10:43 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
trace strings out....
no one has rushed to hand you an answer, perhaps you can try to look this up yourself.
My first guess is there may be a short the control circuit is protecting itself against or the module needs some quick soldering to refresh junctions.
- Paperwork study :
I would get the schematic applicable to your car and trace things out around the light control module.
- Hands-on style:
You're going to need to dis-join all the light strips to figure what gives.
Trims are somewhat easy to remove and reuse without any broken plastics.
+++++ LIN Strings:
it would be interesting to figure if the ambient LED accent is made of many independent LIN segments or centraly connected to one LIN module.
Old Nov 8, 2021 | 11:11 AM
velryba's Avatar
E220d
Thank you for the reply.
I should have been more specific. The LED strip light I meant the white light in the front of the rear view mirror.
Old Nov 8, 2021 | 11:19 AM
INDEPENDENT strings
- Paperwork study :
- Hands-on style:
+++++ LIN Strings:
It just so happens that I had my rear door panel removed yesterday...
I traced the two lighting strips independently running straight back to the Door Control module - So each LED string *IS* indepently supplied.
(Don't overload these outputs or short circuit them to avoid surprises with DCU!)
