E-Class (W213) 2016 - 2023
Illuminated kickplates
Old Dec 29, 2021 | 12:12 AM
Dallasite's Avatar
2018 E300 Sport/ Diamond White
Hi all,
I have an ‘18 E300 and I would like illuminated lick plates on the front door sills.
do any of you happen to know if the cars are pre-wired for illuminated kickplates? Just curious if it is as easy as a plug and play type of thing or if the conversion of extensive
Old Dec 29, 2021 | 09:47 AM
Diesel Benz's Avatar
Originally Posted by Dallasite
Hi all,
Mercedes does not install wiring like this to the car unless the option is ordered from the factory.
There is however a retrofit guide on WIS. Not exactly straightforward as the wiring needs to go across the cabin and to the fuse box etc. but still doable.
Old Dec 29, 2021 | 09:50 AM
konigstiger's Avatar
'71 Pinto
Contact dealer to confirm kit part # 2056806510, requires install. Reply if still interested I will post installation process.
Old Dec 29, 2021 | 11:24 AM
CLKThreeTwenty's Avatar
E400d 4Matic AMG Line Premium Plus 9G-Tronic WHITE (W213) 2019
Can't they simply be piggy backed off their respective door puddle light wiring?
Old Dec 29, 2021 | 01:24 PM
Dallasite's Avatar
I believe MB parts kit is 2056861600 confirm with dealer, requires install. Reply if still interested I will post installation process.
yes, thank you. Please provide the installation instructions when you can. I would greatly appreciate it.
Old Dec 29, 2021 | 01:43 PM
'71 Pinto
See attachments.
