E-Class (W213) 2016 - 2023
Battery tender recommendation SL550
Old Jul 12, 2022 | 09:30 AM
JLowe29101's Avatar
2007 SL550
New Mercedes owner here !! I just bought a 2007 SL 550 and do not drive it much. I know it has 2 batteries in it and will probably need to put a trickle charger on it as it won't get driven but once every couple of weeks. The question is what trickle charger is recommended for this car? Do I need to just keep the main battery charged or both? Does it need to be hooked directly to the battery or thru a cigarette lighter? Sorry for all the questions, but never owned a Mercedes and it came with no manuals! Thanks in advance and sorry again if this is in the wrong area of the forum!
Old Jul 12, 2022 | 10:13 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
wrong forum. but in any case if you search you wil find quite a fe threads with the same question...
Old Jul 13, 2022 | 01:14 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Benz battery float
At the end of the day... buy a CTEK float charger or similar favorite for your MAIN system battery.
Disconnect the AUX to prevent discharge and float once a while.
Old Jul 13, 2022 | 04:56 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
I believe, but I could be wrong, that there is no reason to disconnect the AUX battery: By charging the main battery you also charge the AUX.
I agree that a CTEK charger is an excellent one. They make the chargers branded for Porsche and Mercedes Benz.
On my Boxster, 2008 I was able to keep the trickle charger through the cigarette lighter - it was always live and I used the Porsche branded CTEK. However on my 2019 E450 the cigarette lighter after the ignition is turned off goes dead so to put a trickle charger on you must connect to the main battery terminals, which are under the hood.
Hope that this helps.
