Burst bladder on driver seat
I've got hissing sound coming from driver seat. After disassembling the backrest i saw that the left side (outside) on my lateral support has burst bladder and dynamic function on my seat is limited. Switched it off, because the pump wouldn't stop working and this could cause a fail on pump too. = I located the hole, it's approx. 3 cm which is a lot by my opinion (see pics). Can it be replaced only the popped bladder or i need to replace the whole system at the seat (incl. backrest and right bladder too) ? I will try to fix the bladder by using some vinyl glue and proper patch for it (may be from boats) + duck tape for extra secure, because the crack is on the edge and i think it will pop up on other place next time. If MB sold bladders separate i will consider buying one. If so, can somebody tell me the exact part number, my VIN is : WDD2130051A517284 .
Otherwise i'm open to any ideas of fixing it as it should be done, so if someone has experience with this kind of issues, please share it.
I’ve tried many techniques for repairing a bladder and nothing holds if they are something you plan to use. I’ve tried everything from vinyl repair kits to vinyl or rubber cements to impulse sealers to an iron. If there’s one hole in any seam, as soon as that hole is closed, another part opens up and will continue and continue.
i found this: https://www.buymercedespartsnow.com/...ort-2389107705
not available. would anybody know on the part numbers, is that for the coupe/convertible or would it work for sedan as well? since the part # starts with 238
