Tire Rotation not on Service A or B
https://www.homedepot.com/p/RYOBI-ON...65K1/320033027
https://www.homedepot.com/p/RYOBI-ON...01K1/316879157
- Rearward Cross: This pattern is the opposite of the forward cross, and best suited for rear- and four-wheel drive vehicles. You bring the front tires to the rear and the rear to the front, all the while switching sides of the front tires when bringing them back. So, the front right tire now becomes the left rear tire, and the left front tire becomes the right rear tire. Just like the forward cross pattern, you need not switch sides for the rear tires that move forward.
Some places actually suggest every 3-5k for AWD.
I have staggered so Rotating a thing of past as I cannot see myself moving lefts to rights and rights to left. I gain nothing.
The whole point of rotating is to extend tire life since most of the time the driven tire wears faster.
but if you Rotate then you end up buying all 4 tires at same time...
Whereas with my car I buy rears about halfway thru life of front. I attribute most of this to wider rears and they tend to be softer, lower mileage tires
Now on wife FWD car I buy 2 new tires when the fronts wear out and put these new ones on the rear and move the rear ones up front.
I find I am buying less tires over 100k miles then when I rotated every 10K (oil change interval)
I believe it is better to continue to have the tires rotate in the same direction: I rotate front to back same side which does not change the rotational direction of the tire
I can say I do not remember.
BAck from reading mine and dayum there is about 25 pages of Tire info in the manual; some higlights:
a little blurb about if different sizes tires then DO NOT ROTATE
Those with TPMS should have shop do it
Rotate per tire manufacturer warranty book
If no book, Rotate, every 3-6k miles
DO NOT Change Direction of Wheel Rotation.
And then another 10 pages of tire info....
Thinnk the Manual pretty much covers everything you need to know about tires
Labeling the outside wall
Apparent center V groove
I just rotated mine with the backs to front same side and fronts swapped sides to rears.
Directional tires typically have a clear Rotation “label” with arrow symbols.
