E-Class (W213) 2016 - 2023
E350 media freezing
Old May 29, 2023 | 03:32 AM
martinbh's Avatar
E350
E350 media freezing
I have E350 2018 media version ntg5.5.
when i start the car and plug the usb stick with music -> the whole media is freezing and only the radio works fine.. Bluetooth for music and USB are loading too much time.
for bluetooth it is freezing on “Bluetooth audio stopped”
for USB it is freezing on “USB is loading”
i tried all formats of USB
Old May 29, 2023 | 08:11 AM
ua549's Avatar
Which USB port are you using and have you activated it as a music source?
Old May 29, 2023 | 09:33 AM
martinbh's Avatar
E350
i am using all of them 1,2,3 and it is freezing but of i stop the engine… start the engine again it is playing after 10 seconds
Old May 30, 2023 | 02:23 PM
W205C43PFL's Avatar
What format is your USB formatted too? Does it freeze as well using an SD card?
Old May 30, 2023 | 03:10 PM
ua549's Avatar
When formatting a USB or SD device the address is limited to 32 bits.
Use the default cluster size.(allocation unit).
Unless one has special needs, NTFS is the best format followed by exFAT.
Do not format as FAT32.
Old May 30, 2023 | 06:24 PM
W205C43PFL's Avatar
Good information, hence why I was curious what format is OP's storage media running in.
Old May 31, 2023 | 08:27 AM
martinbh's Avatar
E350
it is the same with all formats….still freezing and load after 1,2… 10 mins
Old May 31, 2023 | 10:21 AM
ua549's Avatar
How many files are on the media? Per the Operator's Guide not all USB drives are compatible with the entertainment system. Personally, I use a 32 GB mSD in an SD adapter formatted as NTFS. It doesn't intrude into the console space. I have about 2k songs and 3 movies on it. (The movies are for when I'm waiting for my wife.)
Old May 31, 2023 | 10:51 AM
martinbh's Avatar
E350
so in general.. the media is taking too much time for load the usb and while loading usb it is freezing the whole media (it is too slow)
i have tried a lot of usb sticks, different formats, 1 file, 200 files all but no success
Old May 31, 2023 | 11:44 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
what's the comand version?
cos if it's never been updated, it's normal that it's slow as sh*t
my new 2017 was terrible until they update it
Old May 31, 2023 | 01:15 PM
martinbh's Avatar
E350
NTG 5.5 … how to check the version?
Old May 31, 2023 | 06:47 PM
W205C43PFL's Avatar
Latest is 06.80.00.40 I believe?
https://mbworld.org/forums/e-class-w...ml#post7577603
Old May 31, 2023 | 06:48 PM
W205C43PFL's Avatar
I heard the partition table might affect it too (on top of if the COMAND version is old), GPT/GUID might yield issues, MBR might not.
Old Jun 1, 2023 | 07:43 AM
The G Man's Avatar
2019 E300
Are you plugging in the USB when the computer is booting up? That might explain why it works if you re-insert it the second time. Try leaving the USB in the socket or maybe try another USB drive.
Old Jun 1, 2023 | 11:28 AM
LMinn's Avatar
2023 E63s Sedan, 2020 E53 Sedan
This is a good question, because the audio head takes a bit longer time to fully boot up. I would cite where I heard this but I forgot, so I can't say 100% if that's true or not. Just a thought.
Old Jun 1, 2023 | 06:27 PM
The G Man's Avatar
2019 E300
My 2019 takes forever to load up audio, the 2018 might have a older unit that is slower. Trying to insert and recognize the usb drive when the audio program is still loading might cause issues.
Old Jun 2, 2023 | 07:41 AM
ua549's Avatar
My '18 E300 with COMAND loads 2,100 files of audio & video in a few seconds of when I either start the car or turn the system on. I use the SD slot with a mSD card and SD adapter. I don't have a USB stick or I'd compare loading times.
Old Jun 2, 2023 | 05:12 PM
The_Judge's Avatar
2018 E400 Coupe
In the audio system of my 2018 E400 Coupe I have an old 128GB 95MB/s SD card in NTFS format. It's loaded with 4,834 tracks divided into four categories: Classical Albums (1,074 files in 175 folders), Jazz Albums (629 files in 66 folders), Rock, Folk & Other Albums (741 files in 70 folders), and Miscellaneous MP3s (2,090 files, 0 folders), a total of 29.8 GBs of music. The car has no problems instantly finding or playing any of the files; the only problem is choosing what I want to listen to! 😵
Old Jun 2, 2023 | 05:25 PM
ua549's Avatar
I have mine set to random play. I do not need to make more decisions, especially while driving.
