OBD Diagnostic for W213 with DPF Regen function
Subscribe
Oct 9, 2023 | 07:28 PM
Hi guys, new here with a 18reg E220d
Juat wanted to ask,which diagnostic would you recommend with a dpf regen function?
I read good things about icarsoft v3 for Mercedes, also there is the Launch Creader Elite for Mercedes, anyone got experience with these 2 also any other recommendations without breaking the bank,I know Xentry is the best by far but a setup is too expensive and can’t justify it right now, other than the tablet it requires the C4/5 multiplexer and it’s just a bit too much for my needs.
I want basic functions like reading any faulty codes/erasing them and then DPF readings and force regen if necessary.
thanks in advance
Reply 0
Oct 12, 2023 | 05:19 AM
Due to the engineering of the enginne and the very close coupling of SCR and DPF then no forced regen should be requried, even for those cars that sit in town all day. This engine was engineered at a cost of over €1bn to ensure things were done correctly (including reducing the heat of the regen when in traffic so that the exhaust output is lower so as not to burn pedestrains walking behind the car).
I use a Thinkdiag2 reader to read codes/delete codes and also conduct bi-directional coding of modules.
Reply 1
Oct 12, 2023 | 11:38 AM
Quote: Due to the engineering of the enginne and the very close coupling of SCR and DPF then no forced regen should be requried, even for those cars that sit in town all day. This engine was engineered at a cost of over €1bn to ensure things were done correctly (including reducing the heat of the regen when in traffic so that the exhaust output is lower so as not to burn pedestrains walking behind the car).
Many thanks for the reply, I do appreciate the extra information, MB R+D is on another level yes.
I am having a look at the Thinkdiag2 and it looks very capable, plus it's equally priced as the launch CReader for MB, very tempting.
Reply 1
Subscribe
Currently Active Users (1)
