Replace TPMS Sensors When Replacing Tires?
They work fine. My car is now 5 years old, 41,000 miles and the TPS work like day one.
Hope this helps.
Those new sensors may indeed work much longer than the old ones from 2003 or so. We had flat batteries on a 2003 car after 5 years and the car had winter tyres almost half a year every year. The old style sensors were active all the time, ready when ignition was switched on before the car moved unlike the current ones. Much more battery drain.
When I replaced my tires, I bought non-runflats at Costco, and they recommended replacing the sensors, which I did.
Outside of Mercedes experience, the sensors on my truck went bad after ten years and very low milage (less than 20k miles). The sensors on my motorcycle went bad at about eight years with similar milage.
"The estimated life expectancy of an OE TPMS sensor is 5 to 12 years, with the average lifespan being 7 years. TPMS life expectancy is directly related to the number of radio frequency transmissions the sensors make. Driving habits greatly influence the number of RF transmissions a sensor makes in its lifetime. For example: sensors usually transmit when the vehicle is stopped and transmit more often when in motion. Maintaining a constant speed, such as when you're on a highway, reduces the demand on TPMS sensors and allow the sensors to transmit less often. Drivers who often find themselves driving in start-and-stop type traffic will have a greater impact on the vehicles tire pressure monitoring sensors. Weather can also have an impact on tire pressure sensor battery life. Cold conditions allow batteries to last longer. Warmer conditions take more of a toll on TPMS battery life."
https://www.tirereview.com/changing-...sor-batteries/
“10,000 city miles will result in lower battery life compared to 10,000 highway miles.”
"When a customer visits a tire dealer, a technician can test each TPMS sensor’s battery life, but only if his or her scan tool can display battery life and the pressure sensor is equipped to output that data. Rigney cautions that it’s difficult to interpret the scanned data, because the readout could be a battery life percentage or a one-word description. “A displayed ‘10 %’ or ‘low’ could mean six months to a year of battery life remaining,” he says. The lack of accurate information opens the door for a conversation to discover a customer’s expectations and explain the needs. He adds that if a vehicle owner is buying new tires and one sensor battery is dead or low, the technician should explain it’s the best time to replace the sensors because the tires already are off the wheels, so buying now means avoiding a future visit to the dealer and additional charges for a second service."
Everyone should have one of these:
see:
FWIW: My car has 41,000 miles: Rear brakes and rotors, badly scored, replaced at 31,000 miles: Shop said wear to rotors was caused by electronic rear brakes. Second shop confirmed. Front pads are still good and rotors are smooth.
Wait for them to fail is my advice unless you really cannot deal with another service. Mine went 11 years.
I've never had one fail myself, but if I did, I would replace all of them at that time. It's not a concern of mine, but I get it if it is to you.
Another note: If you have a model that reports tire pressure and tire temperature, make sure the replacements have temperature sensors also.
I replaced the sensors on my Mercedes when I bought new tires, and I think that was easier. I guess it depends on how often you replace the tires and how long you plan to keep the car.
