E-Class (W213) 2016 - 2023
TPMS Sensor
Old Jan 13, 2024 | 10:48 PM
ozzyk's Avatar
2017 E300
TPMS Sensor
Hi all,
I have a 2017 E300. One of the tpms sensors is gone bad. Can I just replace the sensor and it will sync when I drive or should I get it programmed after repleacement?
Thank you
Old Jan 14, 2024 | 09:43 AM
Diesel Benz's Avatar
No need for any programming. Just have a new sensor installed. On a 2017 you probably need to reset the system from the instrument cluster service menu (no harm doing it even if it was not necessary).
Old Jan 14, 2024 | 11:41 AM
ozzyk's Avatar
2017 E300
Thank you
Old Jan 14, 2024 | 01:08 PM
JakeW213's Avatar
W213 220d from 2016
Unless its pre-coded(bought directly from mercedes) it needs to be programmed.
when I got one relaced, the wheel guy placed a wireless device close to it. Im am pretty sure, that if its a generic one, it needs to be told what car its now supposed to work on.
but its a simple task, and your wheel guy will mostlikely do it with no extra charge.
but if you just buy one yourself and install it(pretty big tax for a dyi - as you need the wheel off the rim) it will not work
Old Jan 15, 2024 | 12:29 AM
I thought the OP was after any need to program the car (with official diagnostics tools or such). Now I'm not sure any more. I know there are car brands where new OEM sensors need to be coded to the car with their service tool. Anyway, if you purchase TPMS sensors for your Mercedes, you would expect you get sensors for your Mercedes. Meaning they are OEM parts or after market parts that are coded to be identical to OEM sensors no coding is needed afterwards, car or sensors.
At the moment I actually have after market sensors in my car (winter tyres). Obviously coded at the tyre shop. DIY sensor and tyre installation is not a problem in the sense that after market sensors can be coded even when installed, our tyre shop did that for a set of new winter tyres (while first installing, he thought the wheels were for a different Mercedes).
Old Jan 15, 2024 | 02:13 AM
JakeW213's Avatar
W213 220d from 2016
I am pretty sure, that if you have a broken tpms and you go to a tireshop that sells tpms valves. They will clone one of the existing ones with a tool, so that the replaced tpms valve will act as the one replaced.
but if you just buy the part yourself…(unless its from mercedes and precoded… if thats a thing) im sure it lacks the ability to know what car its on… it needs to be told by the tool the tireahop has for this purpose.
But the car itself does not need any coding
Old Jan 16, 2024 | 02:31 AM
Sorry but I feel your statement brings unnecessary confusion. An OEM part from Mercedes does not need any coding or precoding. OEM spare parts are for a particular model and work on the car without any preparations. You should just say "unless it is from Mercedes".
Old Jan 16, 2024 | 05:53 PM
SpeedracerZ's Avatar
2018 E43
I have a 2018 E43. The TPMS sensors I purchased from Tire Rack did not need programming. I had to drive the car for several miles but they eventually learned on their own. Also when I swap winter and summer rim/tire sets some thing. Eventually learn on it's own.
