I知 gonna make the switch to non run flat tires
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
2. For winter use, how much winter driving do you do? I've run proper summer and winter sets for some time. I'm a bit conflicted on this because my sets have lasted a long time. If I run a/s I'm going to end up pre-emptively swapping out moderately worn tires before winter.
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/1000x750/winter_slk_2_249442769a61b7940394b6b5dcd1d9f6ca6f4e7b.jpg)
3. Have you found the tires softer or more vague on initial turn-in?
What the DWS06 gives is a quiet, super handling/compliant ride, and a somewhat long thread life... in my staggered configuration, I have had fronts for 30K+ miles, and rears for 25K+ miles... despite being a lead-footed driver
Hope the above helps address your questions.
There are Firestone Indy 500's that are 10mm bigger than the E53 staggered sizes. They're the correct OD but run over an inch wider, fit the stock rims.
I had them on a Jag XFR and they are a bit meatier than Pilot Sports but are still quiet and great tires. Most of the difference is probably due to being a hair wider than the PS.
This is very helpful!
I've driven a lot in the winter, I'm nearly 50 and before this I've never had anything other than a RWD car as my personal winter vehicle.
I had the DWS06 on a couple Mazdaspeed 3's way back. Wore quickly but I'm sure it has evolved.
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
On our 2013 R231 and 2019 A238, when the OEM RFT became too harsh due to wear, we switched to Michelin Pilot Sport A/S 4. It really transformed the ride of those two vehicles, both with 19" wheels. On our current S213, when it came time to get new tires, I elected to go with the Michelin Primacy Tour A/S ZP. Several of my car friends stated that this was a great tire, so I thought I would try them.
We have 18" wheels, and I can say that I am quite pleased with the ride, handling and noise level of these tires. The wagon calls for an XL tire, and this tire is only available in SL rating in our size; however after talking with the tire gurus, looking at weight ratings, comparing 'carcasses', etc., we made the move. Right now I have over 8,000 miles on the tires, around town, long haul 1,000 mile runs, and many trips to the lake. To each his own, but after this experience my perspective on RFT technology has been altered, now to see how long they last.
