E-Class (W213) 2016 - 2023
P219E , need vehicle fixed ASAP
Old Jul 10, 2024 | 09:08 AM
Giovanni21M7's Avatar
E350
Hello all, new Mercedes owner here, recently bought a 2021 E350. Check engine light came up just two weeks after purchasing car, took to the Mercedes dealership and they diagnosed and said it’s the cylinder itself and quoted me $9500 for parts and labor.
I need this car fixed ASAP, active duty military and I have to drive from Florida to California.
Fault codes:
P030085
P030385
P219E77
P1CE577
P1CEF85
these are the codes the Service Advisor said.
went to autozone and had free Check engine light check prior and the only thing that popped up was a P219E code for Air to fuel ratio imbalance.
Symptoms:
Engine Misfired and was shaking pretty bad, happened once, hasn’t happened in a few days. Done quite a bit of research and I’m thinking the three things I’ve boiled it down to could be the
1. Spark plugs
2. MAF sensor
3. O2 Sensor/s
this is just off of research but I would definitely appreciate any knowledge or advice from the MB Masters. I literally know nothing about cars.
Old Jul 10, 2024 | 11:56 AM
The G Man's Avatar
2019 E300
Is it the #1 cylinder? Did the car have any engine issue on carfax? Any tune on the car?
Hopefully its nothing serious like a cracked piston, block or header.
Old Jul 10, 2024 | 02:56 PM
E350
Originally Posted by Plutoe
Quickly get a second opinion---but what do they mean by cylinder---what parts bla bla
im planning on taking it to a euro shop nearby soon, the service Advisor just said the cylinder itself needed to be replaced. Sent me an invoice with like 20 parts that are part of the repair.
Old Jul 10, 2024 | 02:58 PM
E350
no it’s cylinder #3, no issues on carfax and no tune. I’m also hoping it’s nothing serious, I might be in denial bc I’m telling myself it can’t be something that serious since the car is fairly new.
Old Jul 10, 2024 | 04:02 PM
The G Man's Avatar
2019 E300
does your exhaust smoke up or the exhaust turned color, like dark grey, brown or black? Agree with other post, need second opinion on cylinder replacment. I am guessing they mean replacing the cylinder lining and the rings or rebuilding cylinder #3.
Old Jan 4, 2025 | 10:22 PM
somoler's Avatar
Hi, I have the exact same problem. Did you find the issue?
[QUOTE=Giovanni21M7;8999258]Всем привет, новый владелец Mercedes, недавно купил E350 2021 года. Индикатор Check Engine загорелся всего через две недели после покупки автомобиля, отвез к дилеру Mercedes, они провели диагностику и сказали, что это сам цилиндр, и назвали мне 9500 долларов за запчасти и работу.
Мне нужно как можно скорее отремонтировать эту машину, действующая армия, и мне нужно ехать из Флориды в Калифорнию.
Коды неисправностей:
P030085
P030385
P219E77
P1CE577
P1CEF85,
это коды, которые сказал сервисный консультант.
Пошел в Autozone и прошел бесплатную проверку индикатора Check Engine, и единственное, что выскочило, был код P219E для дисбаланса соотношения воздуха и топлива.
Симптомы:
пропуски зажигания в двигателе и довольно сильная тряска, случилось один раз, не случалось в течение нескольких дней. Провел довольно много исследований и думаю, что три вещи, к которым я это свел, могли бы быть
1. Свечи зажигания
2. Датчик массового расхода воздуха
3. Датчик(и) кислорода
это только часть исследования, но я определенно был бы признателен за любые знания или советы от MB Masters. Я буквально ничего не знаю о машинах.[/QUOTE
Old Jan 5, 2025 | 08:47 PM
somoler's Avatar
Old Jan 9, 2025 | 05:09 PM
Grygson_PL's Avatar
GLC 300 2021 258 HP 45 000 km. The same problem!!
Hi, I bought GLC300 2021 with 45 000 kilometers.
After 3 thousand kilometers “check engine” appeared and I heart from exhaust different noise like misfire on cylinder.
After checking DTC:
-P219E77
-P1CE577
-P1CEF85
Checked spark plugs. At 3rd cylinder plug was definitely smoked than others. Changed to new spark plugs.
Also nothing the same problem. my brain couldn't accept that at such a mileage there could be a problem with compression pressure, but I checked it. And???
At 3rd cylinder 8 bars, others 12 bars.
Tried to fix with chemicals with 24 h on cylinder but, results were 9.0 bar 3rd/ 14 bar others.
I think there is problem with valve or break piston…
Mercedes = **** = nowadays
Old Jan 10, 2025 | 08:45 PM
Cosworth2000's Avatar
2022 E53 AMG
You have an injector in cylinder 3 likely stuck open since the OX sensor does like the amount of gas being through at it.
