E-Class (W213) 2016 - 2023
Garmin pilot actual position
Old Nov 15, 2024 | 09:49 AM
Dale78's Avatar
W213
Hi, my Garmin GPS shows actual position beside the road, not always but often. I replaced gps antenna but no change. Any advise where to look? Thanks.
Old Nov 15, 2024 | 10:11 AM
ua549's Avatar
It is the mapping and GPS variation/tolerance. Thre is nothing to fix.
Old Nov 15, 2024 | 11:11 AM
Dale78's Avatar
W213
Cannot believe that, it started at one moment and becomes more and more frequent, I even cannot rely on it when going somewhere. It used to work ok. I use garmin on my bike and works perfect.
Old Nov 15, 2024 | 01:36 PM
ua549's Avatar
Is the position is correct at another distant location? I had a Garmin Street Pilot Color 25 years ago that acted in a similar fashion. Many times my track was 50' parallel to the road. The Garmin map was the source of the problem. The problem would either go away or pop up at a different location after each map update. Keep in mind that GPS accuracy is about 7 meters 95% of the time. Sometimes accuracy can be 4 meters or better, but it is a moving target that is dependent upon atmospheric conditions. GPS shows an approximate location, not an exact location.
FWIW I check my GPS location coordinates every morning using my cell phone. Though the phone is in the same exact physical position, the GPS position is never the same 2 days in a row.
Old Nov 15, 2024 | 04:19 PM
Dale78's Avatar
W213
Thanks for explanation. If I drive down the road to my house, it's fine, but if I drive the same road back, it's alway beside the road, cannot really understand that, it's the same road.
Old Nov 15, 2024 | 04:54 PM
Dale78's Avatar
W213
If possible, I can try to renew the card, but not sure if MB/Garmin still supports this.
Old Nov 15, 2024 | 05:05 PM
ua549's Avatar
If your position is within the 7 meter (23 ft.) envelope, GPS is working within specs. Keepng in mind that conditions are not static. Position repeatibility better than 7 meters is not something that you should expect especially with inexpensive consumer grade equipment.
Old Nov 15, 2024 | 05:14 PM
Dale78's Avatar
W213
Iam sure it's more then 7m, my estimation is about 15-20m. If I am not wrong, 7m corresponds to the circle range around the arrow(cursor)?
It all makes sense what you say, although it was working fine some time ago and seems like it's getting worse.
Old Nov 15, 2024 | 05:24 PM
ua549's Avatar
That means the circle around the cursor is 14m (46') diameter.
Old Nov 15, 2024 | 05:47 PM
Dale78's Avatar
W213
If the circle is 14m, and the circle is not touching the road, i.e. the road is far away behind the circle, it's definetely much more then specs. But ok, if there is no module or anything that might have gone wrong, I can give it a try and replace my card.
