E-Class (W213) 2016 - 2023
Fuse location for driver side heated seat
Old Dec 29, 2024 | 04:30 PM
Totalnoob_1's Avatar
Hi, the driver side heated seat (RHD vehicle) is not working and the fuse location diagrams are confusing so was wondering of anyone is able to help identifying which fuse slot is it?
I know the fuse is a 30A fuse for the front heated seats.
The car is a W213 E220d 2018 model year
Old Dec 30, 2024 | 06:47 AM
ua549's Avatar
Look at the fuse block located in the trunk. It should be #453. That's the location for a US model.
The Operators Manual for your car will also shoe the location.
Old Dec 30, 2024 | 09:20 AM
Car is a UK model so driver seat is on the right. And I've checked what I think was #453, isn't that a mini 30A fuse? Since the slot looks like it doesn't have 2 pin ports?
If you could help me pinpoint the exact port on the picture that'd be much appreciated.
Old Dec 30, 2024 | 10:38 AM
ua549's Avatar
One at a time pull each fuse to see if it is blown.
Old Dec 30, 2024 | 10:41 AM
Here's the crazy thing dude, someone (probably a corrupt mechanic) seemed to have tampered with it. So the passenger side heated seat wasn't initially working but I managed to pinpoint the missing fuse and buy a set to remedy that.
So my suspicions are the driver side has also been tampered with and someone dodgy must have removed it. But the diagram for the rear fuse box is so confusing unlike the LHS footwell one so I'm not sure which slot it is.
Bit of an annoying situation!
Old Dec 30, 2024 | 10:44 AM
ua549's Avatar
Look here - W213 Fuses
Old Dec 30, 2024 | 10:49 AM
I've checked that thread, still having difficulties pinpointing the fuse. All the diagrams say it's a 30A fuse and just to let you know that the 30A fuse you see on the picture I sent, ignore it as I placed that there to check but that one didn't work.
Old Dec 30, 2024 | 10:51 AM
I'm having difficulties pinpointing fuse #425 & #453 as stated on the fuse location diagrams
Fusebox I'm seeing
Fusebox I'm seeing
Old Dec 30, 2024 | 11:56 AM
ua549's Avatar
Your fuse panel is different than mine as is the diagram. All I can suggest is to try a fuse in slot 452.
My seats work. I have a fuse in 252 and none in 253.
Old Dec 30, 2024 | 12:03 PM
252 & 253?
Don't you mean 452 & 453?
Old Dec 30, 2024 | 12:07 PM
ua549's Avatar
Yes, sorry for the typo now corrected.
Old Dec 30, 2024 | 12:13 PM
You made me look around for those fuse slots you quoted and I didn't find anything so was confused what you exactly meant.
Old Dec 30, 2024 | 12:37 PM
So I've connected the fuses and now the driver side heated seat works but the backrest heater doesn't work.
I'm just gonna assume it's faulty
Thanks for the help regardless
Old Dec 31, 2024 | 07:03 PM
Quick little update, both heated seats fully work.
Appreciate the help.
Old Dec 31, 2024 | 08:33 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
It would be helpful to others if you posted just what you did to get it working.
