Thief jacked up my car overnight, stole wheel hub and...
overnight somebody jacked up the car and it seems they took the wheel hub from the rear passenger side they didn't take the wheels or rims I went underneath didn't take the categoric converter I started the car no check engine lights and sounds normal. They left the car supported on a milk carton.
but I know they took some parts I just don't know what if anyone can look at this picture and tell me what's missing that would be such a help thank you so much for anyone that can advise advisewhat's missing.
2010 E350 Coupe
2. They did not take your "wheel hub". I'm not sure what you're referring to as your "wheel hub", but in the pictures you posted they are all there. In order to take a wheel hub, the thief would have to remove the break rotor/caliper, center axle bolt, etc.
3. Judging by your pictures, you might need rotors/breaks soon. Get them inspected.
4. All your suspension components seems to be intact. I don't believe they stole anything.
seriously though this sucks
Happened to me about 15 years ago, they stole my 4 wheels
very weird to find your car like that in the morning!
Did they take the wheels and tires?
Did they take the lugnuts?
nothing else appears to be missing.
Can you circle what you think is missing in your pic?
the tire and all the lug nuts were a few feet away on the ground nothing else was taken no attempt to get inside so I just got lucky and thank you for your reply.
So in the end, you got a good scare, a milk crate, and a jack?
Wheel hub is cheap and stealing it require 5x more effort, which worth 5x less. Pretty sure your wheel hubs are still inside the rotor (i doubt that they would put your rotor back after taking the hub away)
