E-Class (W213) 2016 - 2023
Laminated door glass upgrade
Old Mar 12, 2025 | 08:27 PM
Corske's Avatar
W213, W209
Lightbulb Laminated door glass upgrade
I am trying to upgrade all 4 windows on my 18 W213 from regular/acoustic to laminated glass. For who doesn't know the laminated is constructed of two plies of glass which are bonded together with interlayers to form a permanent bond so basically makes it hard to break, it will be just like the windshield.
Anyway, I am doing research to find out the correct number number for these parts however I am getting mixed results as some of the regular glass is labeled laminated. For example some of the sellers are selling door glass with this marking on it as a laminated glass, I can confirm that this is not laminated as I do have the same glass on my vehicle:
Regular (non laminated) glass marking
Taking as an example the driver side door glass I am coming up with three different part numbers :
  • 213-720-84-02-64
  • 213-725-01-10
  • 238-725-01-00
Not clear which one is the laminated one.
If you have a vehicle with laminated windows please chime in or if you have any ideas to clear up the confusion please help.
Old Mar 13, 2025 | 08:29 AM
ua549's Avatar
My '18 E300 has laminated side glass.
The data card shows option 596 HEAT INSULATING+IR REFLECTG.SAFETY GLASS ALL-ROUND and PAF ACOUSTIC COMFORT PACKAGE.
The glass markings are:
  • 43R-010485
  • DOT-24 M236 AS2
  • TRANSP 70% MIN
  • E 000255 20C
  • AGC AUTOMOTIVE
  • OCP N° 0009
  • 16 • • • •
Old Mar 13, 2025 | 10:59 AM
Corske's Avatar
W213, W209
  • 43R-010485
  • DOT-24 M236 AS2
  • TRANSP 70% MIN
  • E 000255 20C
  • AGC AUTOMOTIVE
  • OCP N° 0009
  • 16 • • • •
Thank you for that, could you also confirm that the edges of the glass are looking like a two pieces put together (sandwich looking) ?
Old Mar 13, 2025 | 11:32 AM
ua549's Avatar
Yes they are.
Old Mar 13, 2025 | 02:29 PM
Kumar2024's Avatar
2019 MB E450 4matic wagon
I am not a MB expert but i work a lot with glass. I noticed that you called your current side glass as "regular/acoustic". Generally, acoustic performance of glass is enhanced using laminated glass. It is the soft "interlayer" (the vinyl between two sheets of glass) that provides the sound deadning. Solid glass, even if tempered, is generally not considered "acoustic". But your post has gotten me interested in deciphering the markings and notations being used. So I will research that further and let you know if I find something.
Old Mar 16, 2025 | 09:31 PM
Corske's Avatar
W213, W209
Yes they are.
Thanks for confirming, could you also please type the glass markings for the quarter glass, I am trying to find out if these are laminated as well.
Many thanks.
Old Mar 17, 2025 | 08:46 AM
ua549's Avatar
The markings are the same. As stated above 596 HEAT INSULATING+IR REFLECTG.SAFETY GLASS ALL-ROUND
Old Mar 25, 2025 | 10:04 PM
Povitica3's Avatar
2022 C300 AMG-Line; 2020 E450; 2013 SLK350; 2023 EQS580
  • 43R-010485
  • DOT-24 M236 AS2
  • TRANSP 70% MIN
  • E 000255 20C
  • AGC AUTOMOTIVE
  • OCP N° 0009
  • 16 • • • •
My 2020 W213 also has the laminated glass / acoustic comfort package and can confirm this info is accurate for an E with this package. It was (then) an $1100 option so if the OP is looking to add this after market it’ll likely be much higher cost. BTW, the noise insulation is good not great… it’s not like in an S, for sure.
