E-Class (W213) 2016 - 2023
Car locked with keys in it
Old Mar 13, 2025 | 10:52 PM
Bokbfok's Avatar
1966 Mini Cooper S, 2005 Mini Cooper S, 2004 GMC Sierra LB7, 2015 Land Rover LR4, 2021 E63s Wagon
I just got a 2020 e63 wagon, only came with one key. Getting another is on my list but haven't gotten there yet.
This morning, leaving for work I go to get my badge out of the car. I am driving the truck today and my wife will be driving the car. Anyhow, get the badge and leave the key in the cup holder with the cover closed and doors unlock. I opened the passenger door to get the badge. Head to work and wife never needed the car. This evening I go to get the key and the doors are locked. How is this possible? I know there are some features that if you unlock the key but do not open a door, it will unlock but this was not the case. I did not open the rear hatch so there is no possible way I could have hit the lock button on it. Any ideas on this? Other than calling a lock smith or prying a door open and using a coat hanger, what are my options?
If I call the local dealer and order another key, is that an option?
TIA
Old Mar 14, 2025 | 01:35 AM
superswiss's Avatar
2019 C63CS
A couple of thoughts here. First off, it is technically possible to lock the car with the key fob inside, because the key fob has a motion sensor and if it doesn't detect any motion for at least 2 minutes, it goes to sleep and stops sending out a signal until motion is detected again. So when this happens, the car no longer knows that the key fob is inside and will allow the car to be locked.
Having said that, without a second key, nobody near the car could have locked it from the outside. So then the next question is did you transfer the Mercedes me services to you from the previous owner? The car can be locked and unlocked remotely from the Mercedes app. If you haven't transferred the service to you then the previous owner still has control over your car and can lock it from their phone. Perhaps inadvertently or as a prank, they locked your car remotely. This is also the answer to your question. If you ever find your key locked inside the car, you unlock the car from the Mercedes app on your phone, but as said that requires to have the services transferred to you first and you should do that ASAP if you haven't done it already. You will need to go to the dealership and show proof of ownership and then they can remove the previous owner and transfer the service to your Mercedes me account.
If you didn't transfer the services to you and currently can't unlock it from your phone, then unfortunately locksmith it is. The dealership would also have to force their way into the car first to program an additional key. Can't just order one and use it to unlock a car. It's gonna have to be programmed first. The dealership should also remove the second key that is missing, in case someone actually has it in their possession. For all you know, the previous owner still has the second key. Not saying they are stalking you, but I sure would not want a stranger to be able to lock and control my car from their phone, because they previously owned this car. Even worse, they can actually see the location of the car in the app and track you.
Old Mar 14, 2025 | 11:47 AM
The_Judge's Avatar
2018 E400 Coupe
Happened to me once at the care wash. I called MB and they wee able to unlock the car remotely. However, IIRC, to do that it had to be in the open air (i.e., not inside the carcass or any other building).
Old Mar 14, 2025 | 11:58 AM
Bokbfok's Avatar
Thank you for the detailed response. Would the dealer not be able to get me a blade that I can use to open the car, then take it to them to program the fob? I will call them a bit later today to see what all my options are.
Old Mar 14, 2025 | 12:25 PM
Bokbfok's Avatar
Old Mar 15, 2025 | 11:44 AM
Bokbfok's Avatar
My replies seems to be stuck with the administrators. So I will try again.
I had asked if the dealer could just get me a blade that I can use to get into the car. The answer is yes. I called them yesterday and ordered one. Should be here Tuesday/Wednesday.
Old Mar 15, 2025 | 12:37 PM
DFWdude's Avatar
2016 E350 Sport
Worth a try to rock the car at the front fender up/down to see if the key wakes up. Or use a car jack to raise a corner and then let it drop.
Old Mar 15, 2025 | 01:13 PM
superswiss's Avatar
2019 C63CS
Waking the key up won't unlock the car if it's already locked.
Old Mar 25, 2025 | 05:19 PM
Bokbfok's Avatar
I got in the car, bought some items from amazon and got the door open. Didn't want to wait for the blade.
Dealer did call me, and the blade is ready for pickup. I also subscribed to the Me app so I have some options if this happens again.
