E-Class (W213) 2016 - 2023
HUD Alignment ???
Old Jul 16, 2025 | 05:37 PM
BlackCat2021's Avatar
2021 E62s
HUD Alignment ???
All... I had to have my windshield replaced in my 2021 AMG E63s. Since replacement the Heads Up Display is misaligned (has a shadow / blurry effect on each character). IE: the tach numbers have a shadow offset diagonally up and to the left. YES, I had Mercedes do the new windshield install with a Mercedes windshield. The dealer worked on the alignment today for most of the day with the tech giving up. Anyone know how to solve this problem? I have found the HUD service menu and tried a couple adjustments with no real difference, so I just undid the changes and exited. There are all kinds of adjustments in the menu but the darn haptic buttons on the steering wheel make the adjustment process infuriating. Any help here would be appreciated.
Old Jul 16, 2025 | 05:50 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
This is dealer caused problem. They have to fix it. May be defective windshield? Not coded properly? Poor calibration? I have no idea, but someone at Mercedes knows. They have two famous lines when they are out of ideas - 'need software update', or my personal favorite, 'have call into Germany'. You may need to take to another dealer to get satisfaction.
Old Jul 16, 2025 | 08:32 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
One of the reasons to use a Mercedes-Benz dealer for doing this type of work is that they are supposed to be able to do these repairs without any negative impact to the normal functions of the car. This should very much be in their wheelhouse to fix and if they can't they will need to contact Germany to get guidance. Otherwise, what's the point of using MB for any service work.
Old Jul 17, 2025 | 06:42 AM
W205C43PFL's Avatar
You need a HUD specific windshield: https://mbworld.org/forums/s-class-w...indshield.html
Old Jul 17, 2025 | 11:17 AM
vinceleo's Avatar
E450
The HUD display is not misaligned, the reason it appears blurry is correct as per the last post - there is is specific HUD windshield. I picked up a crack on my original windshield and it was replaced with the wrong windshield and I had the blurry/double vision noted in the original post. The glass company replaced it a second time with the correct one on their dime.
On the passenger side, lower corner it lists the options on the windshield (HUD, acoustic, etc.)
Old Jul 18, 2025 | 06:11 AM
W205C43PFL's Avatar
I am always curious actually, what is different about the HUD specific one, use of material? Refraction properties?
Old Jul 18, 2025 | 07:04 AM
vinceleo's Avatar
E450
Not sure if its true, but I was told it has an anti-reflection layer between the layers of glass. All I know is the HUD version fixed the double vison
Old Jul 18, 2025 | 08:03 AM
W205C43PFL's Avatar
Ah, so something like the coating on prescription myopia eyeglasses.
Old Jul 18, 2025 | 06:28 PM
kingscorpian27's Avatar
MB W213 E300 4MATIC Luxury Model
Anyone had a generic windshield replacement installed instead of OEM. I think MB windshields are a bit on the softer side. I have noticed a lot of little dings on windshield, especially at night. Never before on any other vehicle or even my other previously owned MB’s.
Old Jul 19, 2025 | 07:52 PM
vinceleo's Avatar
E450
My replacement is aftermarket and seems fine other than no Mercedes sticker on the lower, passenger side.
Old Jul 19, 2025 | 07:56 PM
Thank you, how long have you had it and have you noticed any difference?
Old Jul 20, 2025 | 07:53 PM
vinceleo's Avatar
E450
They replaced my windshield couple weeks ago - no difference that I can tell in appearance other than no Mercedes sticker.
Old Jul 20, 2025 | 10:05 PM
Ok, let’s see in a year or two. Did you by any chance notice any tiny chips in your OEM windshield before the change.
Old Jul 21, 2025 | 08:14 AM
vinceleo's Avatar
E450
I have always found OEM euro glass to be "softer" and tends to get more chips and sandblasting.
Old Jul 21, 2025 | 11:05 PM
W205C43PFL's Avatar
Why is that?
