2017 E400 air suspension question
I have a 2017 E400 wagon and with the colder weather (well below freezing) I am waking up to the rear seemingly completely deflated and resting on the bump stops, finally got the warning light today.
Compressor still works and gets rear inflated but want to address before issue compounds. My question, the E400 wagon only has air bags in the rear while using air shocks up front, I have found a self leveling air valve block for the rear with three ports but also an air block valve with six ports, does mine have both? I am going to start with the air valve block assuming bad O rings/corrosion causing the leak and work from there, but want to ensure I am addressing the proper one or both if I have two.
If you have the button, you have 4 wheel air suspension.
A slow leak in an airbag (or both)
A hole in the line
A bad compressor
Possibly a sensor
When mine did that, it was the compressor.
Was really looking to confirm proper air valve block as replacing that in turn solves a few O rings and if corrosion if present due to condensation in current unit.
Using that workflow, I’ll replace block/filter/relay first, problem solved, great. If not, I’ll go after the bags, and if I’m still stuck, time to do compressor.
I really just wanted to know if anyone has done non-Airmatic wagon before and if the three valve block is correct, Alldata says it is, MB website a bit murkier.
