E-Class (W214) 2024 -
Tire Pressure Discrepancy
Old Jul 1, 2024 | 12:43 PM
ORCoast's Avatar
2023-E350 4Matic
2023 E350 with 245/40 R19 (Extra Load) front and rear. Tire sticker on driver's door indicates pressure of F-39/R-46 psi. Sticker on Fuel Fill Cap indicates F-33/R-34. Which should I follow?
Old Jul 1, 2024 | 01:09 PM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
fuel cap
Old Jul 1, 2024 | 03:14 PM
W205C43PFL's Avatar
Originally Posted by taphil
fuel cap
ditto
Old Jul 1, 2024 | 04:31 PM
DFWdude's Avatar
2016 E350 Sport
Neither... Follow what is molded on the tire itself. Max pressure minus 10-15%
Old Jul 1, 2024 | 06:26 PM
ua549's Avatar
The door jamb states that the pressures listed are for extra load.
The filler cap pressures listed are for normal load, extra load, normal speed, high speed.
Old Jul 1, 2024 | 06:56 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
If you do this, you will feel every bump, crack and pebble on the road.
With 19" tires, the pressure you suggest, the ride will be intolerable.
I go with the the fuel cap pressures.
For my own preference, I add 2 PSI to the fuel cap. With my 18" wheels, normal load, per the fuel flap that is 33 PSI + 2 = 35 PSI.
Old Jul 2, 2024 | 05:45 AM
ygmn's Avatar
2015 E400 Sedan
Max on tire is to prevent blowing things up and mainly what the max tire load capacity numbers are based on.
max pressure wears tire out in center and reduces handling and braking due to reduce contact area with road.
Manufacturer tire pressure is best place to start and adjust from there but do be careful if you haul near max load and do not have pressure they recommend or more.
Old Jul 2, 2024 | 01:57 PM
Alan Smithee's Avatar
I hope you're joking. Absolutely, positively NOT the correct way to determine tire pressures. Terrible advice to post publicly and likely to cause a blowout as pressures will be at or above max when they heat up.
