E-Class (W214) 2024 -
Playlists for USB Media Player
Old Dec 16, 2024 | 11:19 AM
69GTO's Avatar
2025 E450
I have a MY25 e450 delivered to me Nov 15. Software version E262.3-4975. I am having a problem with the playlists for the USB media player. I have used WPL and M3U playlists created in Windows Media Player. Problem is the songs are not played in the order in the playlist, instead they are played in alphabetical order of the songs in the list. Is there a preferred format for the USB playlists?
Old Dec 16, 2024 | 11:27 AM
gleam's Avatar
M3U should work, but I wonder if Windows Media Player is using the full path to the files instead of relative to the playlist. For example, including the Windows name of the drive. You should be able to open the playlist in a text editor like Notepad and see what the paths are to the files, which might give some clues. Otherwise, I would recommend trying a different tool to generate the playlists.
Old Dec 16, 2024 | 11:51 AM
69GTO's Avatar
2025 E450
The format is actually the extended m3u format. The USB media player does find all the files, it just plays them in alphabetical order instead of the order in the playlist. Here's an example of the playlist format saved by Windows Media Player for M3U:
#EXTM3U
#EXTINF:0,Silence.mp3
..\Silence.mp3
#EXTINF:0,02 Have Yourself a Merry Little Christmas.flac
..\CHRISTMAS\Andy Williams - Merry Christmas\02 Have Yourself a Merry Little Christmas.flac
#EXTINF:0,05 Let It Snow! Let It Snow! Let It Snow!.flac
..\CHRISTMAS\Andy Williams - Merry Christmas\05 Let It Snow! Let It Snow! Let It Snow!.flac
Old Dec 16, 2024 | 11:56 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
When you start a play list there are two icons at the top right. One looks like two lines with arrows forming an X and the other a square. The X will randomize the list while the square will enable repeat. It defaults to repeat without randomization. Tap the X and optionally tap the square. There are two types of repeat so taping that twice will get it to turn off if that is what you want.
Also, I have found that the play list will play in the order they appear in the list. Many play lists will sort the list alphabetical. Typically that should include a naming convention of \artist\album\track where track will include the number of the track. This however, depends on how you store the music on the USB drive. This may give the appearance that it's playing alphabetical when it's really just following the list top down.
Old Dec 16, 2024 | 12:00 PM
gleam's Avatar
Ugh, that sucks. I hate to suggest it, and I suspect you've thought of it already, but you could always prepend the tracks with their number in the playlist. Hopefully there's a better solution than that, though.
Old Dec 16, 2024 | 04:49 PM
69GTO's Avatar
2025 E450
L1WOLF - how did you create your playlist? I can not get mine to play in order.
Old Dec 16, 2024 | 05:24 PM
oncsy's Avatar
W206 C43 ; W214 E53
I used to have the same problem and for me it was not up2 the file format. I have to add numbering 01, 02, 03 to the naming of the files and than it is working
Old Dec 16, 2024 | 06:08 PM
ua549's Avatar
So it is still playing in alphabetic order, 01, 02, 03, ...
Old Dec 17, 2024 | 09:15 AM
69GTO's Avatar
2025 E450
I have verified that the playlist is displayed with the correct order prior to being selected for play, but then it always plays in alphabetical order of the song names (not the track titles which contain the track number as prefix). The song names come from the tags in each FLAC music file. I think this must be a bug.
Old May 4, 2025 | 12:36 PM
69GTO's Avatar
2025 E450
I'm still trying to get my USB playlists to play in the listed order. It always sorts the list alphabetically by song title and plays in that order.
Is anyone else having this problem? I would greatly appreciate seeing an example of a playlist file that plays in the order listed in the file.
Old May 28, 2025 | 07:04 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I was wrong earlier when I said my playlists play in order. Mine were actually alphabetical in the playlist and therefore masked the fact that MBUX sorted it alphabetically. I've tried a few different tests and cannot get the car to not play songs in alphabetical order. One was using extended M3U files to set the track name with a numerical sequence. MBUX ignores the extended tags as any player that doesn't support them. I typically play in random order, but if you wanted a playlist that had multiple albums play in the order they appear on the album, you are out of luck. Unless you tag the file which can get quite messy and not really a viable solution.
Old May 29, 2025 | 11:36 AM
ua549's Avatar
My W213 COMAND system has an option to play randomly from the current medium. My μSD has over 5,000 tracks on it so I rarely hear any repeat music.
Old May 29, 2025 | 04:28 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
That is possible in most any system. I have a large library too (over 6000 tracks), but I prefer to have a curated play lists that I play based on mood and/or passengers. I have a list specifically for my wife who does not like some of the harder stuff I like. Then I have some different mixes of harder rock, progressive rock, and one that just has good high fidelity music. I also have a blues rock, classic rock list, and one with nothing but my favorite band Rush. I would never just have it on full random as there is far too much variety in what I have for my entire collection. I wouldn't want a track from Iron Maden being followed by something from Simon and Garfunkel for example. I also have a growing list of Atmos music that I have a list of just that.
When using random, there are no issues, but the OP and others (including me) are not thrilled by the fact that play lists are by default played in alphabetical order regardless of the order on the list. This means you cannot force a specific order when using a play list. Also, when you start playing a list, it will not remember that you last had random on which means any time you change to play a different list the first track will always be the same until you turn on random and go to the next track. I've learned to live with it and having the Burmester 4D sound helps you forget about some of these shortcomings. Especially when you are playing an Atmos track.
Old May 30, 2025 | 05:56 AM
ua549's Avatar
I use multiple USB sticks to achieve the same playlist results.
