Does the A/C default to ON at every startup?
Variable displacement compressors are much more efficient because they can scale up/down their cooling output to meet the needs of the climate control system. If it's not needed it will be at minimum displacement and have basically no effect and draw an insignificant amount of power, or on the E350 it will disengage the clutch and draw no power at all.
I didn't realize until researching this that the E450 gets a slicker compressor than the E350, and to my mind it's another reason to get the E450 -- the AC should keep blowing cold even if the engine stops as part of the auto stop/start.
If you get a new air conditioner at home and it features multiple speeds or variable speeds for the outdoor unit it’s the same idea. More efficiency when running longer at low power.
see: https://www.google.com/search?q=are+ac+units+on+a+car+fixed+or+variable+s peed&sca_esv=c9ba1905e1b36b97&rlz=1C1SQJL_enUS888U S888&sxsrf=AHTn8zqw4lK1EJYup5hMEspgdilPUWRUIA%3A17 39238363607&ei=26uqZ8rmJNGA5OMPo9-ciAM&oq=are+ac+units+on+a+car+fixed&gs_lp=Egxnd3Mt d2l6LXNlcnAiG2FyZSBhYyB1bml0cyBvbiBhIGNhciBmaXhlZC oCCAAyBRAhGKABMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRig AUjrTVC7DViRO3ACeAGQAQCYAccBoAHkD6oBBDExLji4AQHIAQ D4AQGYAhSgAvARwgIKEAAYsAMY1gQYR8ICBBAjGCfCAggQABiA BBiiBMICBRAAGO8FwgIIEAAYogQYiQXCAgUQIRirAsICBRAhGJ 8FmAMAiAYBkAYIkgcIMTIuNi4xLjGgB4p4&sclient=gws-wiz-serp
see: https://www.google.com/search?q=are+...t=gws-wiz-serp
By the way, I love driving this car.
These are my observations...
- Pressing Auto activates the A/C function. With DAS / Xentry hooked up and viewing the compressor clutch readings - it is engaged at some percentage regardless of ambient temperature.
- To get Auto climate without A/C - ignition 2, press auto, press A/C to deactivate. Press off to turn off the entire system - press off again (rather than Auto) and it will turn back on to full auto remembering that the A/C function was off.
- As for the E53 - you can have a climate shortcut as part of the bottom of the screen - recirculate, A/C and something else. I chose A/C to accomplish the above. After driving for sometime - <30min - the A/C activated by itself. The red line under the A/C went red. That hasn't happened on my previous models.
- So - my efforts are thwarted by the new system architecture. Guessing there is a comfort sensor (humidity?) that reads air quality and adapts.
Change is good.
Change is good.
Turning on the AC to prevent mold has never been a concern of mine.
It is interesting that you note, that regardless of the temperature outside, when in Auto, without turning off the AC, the compressor is running. Regardless of whether the AC is running off the engine or the battery energy is being used: whether it is gas or electricity. Turning off the AC, from an energy point of view makes sense.
As someone else posted: In the winter in your home, do you turn on the AC when the heat is on? Of course not. No different in a car.
Just my $.02
Change is good.
