Does the A/C default to ON at every startup?
Someone please tell me there's a way to change a setting so the A/C remembers my last choice (whether ON or OFF). I read the manual and it seems like there's no way to do this with the AUTO setting activated.
If it were summer I would be fine with the A/C turning ON each time, but having to constantly turn it off in the winter would be annoying.
I feel there's no need for A/C in the winter because it uses more fuel and puts more strain on the engine making it slower.
Hope this helps.
Remember even if it is zero outside, if you put the car in defrost mode, the AC comes on to clear the windshield. In Auto, with the AC on the same: it is on.
The only time in the winter I leave the AC on is when the windows get fogged.
In Vermont when it is zero, if I hit the defrost and have the AC on, it takes much longer for the heat to defrost the window. With the AC off, I get hot air much quicker.
Turn the AC off in the winter: it will save you money.
On my old E class I just set it on Auto with the AC off and I never had an issue with the windows fogging up. Also, it remembered my last setting at each startup, which was the point of my original post.
The car should remember the driver's last setting instead of defaulting to turning the AC on at every startup.
The theory is that yes while you were heating the air, it does get warmer but warm air holds more water, even though the humidity is less. That is the relative nature of humidity. That warm, humid air is what now condenses on the cold window and is usually why the fog appears after the heat is turned on..
and yes, there are some interior home units that do exactly this for humidity control and it is called reheat. Effectively you are running a heater with air conditioning or vice versa and it’s about humidity control.
but as all others see, the heating time does take longer during defrost. My preference is AC off until the car heats up. Or I get the car very hot and crack a window for a second to release the moisture out of that air..
Can anyone confirm that?
I thought if the AC button is on then the compressor is constantly running.
Variable displacement compressors are much more efficient because they can scale up/down their cooling output to meet the needs of the climate control system. If it's not needed it will be at minimum displacement and have basically no effect and draw an insignificant amount of power, or on the E350 it will disengage the clutch and draw no power at all.
I didn't realize until researching this that the E450 gets a slicker compressor than the E350, and to my mind it's another reason to get the E450 -- the AC should keep blowing cold even if the engine stops as part of the auto stop/start.
Last edited by gleam; Feb 10, 2025 at 03:57 PM. Reason: remove E53 since it uses a slightly different model
