E/W214: MotorTrend Review of the W214 E53
Good for you. But I'm amazed at the number of people who salivate over the power of the E53 and ignore the handling hit of the extra weight. I remember reading several review of the 2019 series SL, which could be had as a 43, 53 or 63, the higher numbers adding hp but also weight. The common comment was the added weight of the bigger engines threw the balance of the vehicle off and suspension calibration could just do so much to compensate. I can feel the difference in handling between driving solo and driving with a passenger.
1 | Battery “dead weight” vs. real-world boost
The 400 V P2 pack is only ~420 lb, not “almost 1,000.” Even at “0 mi” displayed range the BMS holds ~30 % reserve, so the motor still handles creeping, coasting and gap-filling torque—they never leave you ICE-only. And for perspective, the E53 curb weight is 4244 lb, ~500 lb lighter than a Tesla Model S while delivering far stronger straight-line punch.2 | Performance delta
Factory numbers are 3.9 s 0-60 (3.7 s with Race Start) and 577 hp / 553 lb-ft combined output. That’s a clear step beyond the E450’s 4.4 s and 375 hp, yet the car will repeat those launches back-to-back because the hybrid system always preserves a boost buffer.3 | Ride, handling & longevity
AMG Ride Control steel springs with adaptive damping plus rear-axle steering (standard) let the chassis rotate tighter than the outgoing W213 while still soaking up Atlanta’s lunar-surface pavement. After ~6 k mi the springs “bloomed” and the ride in Comfort is genuinely supple, with Sport/+ still button-hard when you want it. No premature tire or bushing wear to report.4 | Ergos & visibility
Yes, the default-height “automatic seat fit” can place taller drivers too high—cure is simple: store a manual position in any of the three memory slots and disable Auto Fit. With the wheel lowered one notch the 12.3″ cluster is fully visible, and the seating position stays locked every restart. Takes 60 seconds, not 10 minutes, once you know the trick (Settings > Seats > Driver Fit > Off).5 | Use-case reality check
If your driving is 300-400 highway miles per day, buy an E450 or wait for the diesel. But if you want EV-quiet commuting plus repeatable sub-4-second launches on demand, the E53 hybrid architecture is “elegant tech,” to quote Andreas’ post—and it does so while sipping fuel in traffic and slashing tailpipe CO₂.Bottom line: choose the drivetrain that matches your life, but let’s keep the numbers straight. The W214 E53 isn’t perfect, yet it’s the most versatile E-Class AMG to date.
https://media.mbusa.com/releases/rel...eference-guide
5280 lbs
Motor Trend also weighed the vehicle at ~5300 lbs
Same things with weight, hybrid …with those who never drive a C63s and claimed about 4 cylinders: after 6 cylinders for more than. 20 years, dreaming of a V8 63, I was very surprised of its efficiency and sporty soul so do I with the heavy E53 Wagon I do dayly drive on the same track few minutes later .
E53 is not an RS6 ICE, neither a M5, ICE or hybrid, it’s a dynamic commuter, with top level equipments for the best experience.
What changes (and what doesn’t)
Point from my original post Update Weight comparison – “~500 lb lighter than a Tesla Model S.” Strike that. With the certified mass locked, the E53e is ~500 lb heavierthan a Model S Plaid. Battery mass – “P2 pack ~420 lb.” Still accurate—the 28.6-kWh pack + cooling plate comes in a hair over 190 kg. Performance claim – “3.9 s 0-60 (3.7 s Race Start).” Stands. MT clocked 3.7 s in Race Start on a 5,3-ton curb. Ride/handling, ergonomics, use-case logic Unchanged. Six thousand real-world miles later, all observations still hold.TL;DR I mis-spotted an old data feed; thanks for catching it. Curb weight is 5,280 lb, but every other datapoint—battery mass, hybrid boost behavior, chassis feel, and the “why this drivetrain makes sense” argument—remains spot-on. Appreciate the sharp eyes and the continued debate!
And especially an E53 which is not a competitor of M5 or RS6… or previous E63 V8.
A lot here are talking about an E53 hybrid they never drove, even for a 10’ trip around the retailer. Some have other experiences with other AMG, previous E53, E63 even GLE with less power and 600 more lbs but I drive last week CLE53 just before E53 on road then on track… and something was missing… not 800lbs but immediate torque and 160 HP!
Despite the fact that AMG sports cars are the 63’s, this E53 is only a sporty car… what a E450 is not.
I do make a comparison between my former BMW 545e and this E450 and the E400e before ordering my E53 … and both were far away behind in dynamic handling and performance.
So a another step to the E53…
I own one and have discovered, miles after miles, how impressive E53 hybrid could be but I had to learn how to get the best of it.
The 400 V P2 pack is only ~420 lb, not “almost 1,000.” Even at “0 mi” displayed range the BMS holds ~30 % reserve, so the motor still handles creeping, coasting and gap-filling torque—they never leave you ICE-only. And for perspective, the E53 curb weight is 4244 lb, ~500 lb lighter than a Tesla Model S while delivering far stronger straight-line punch..When you consider weight I suggest that overall weight and not the weight of the battery is relevant. The overall weight of the AMG E53 is almost 1000 lbs.heaver than the E450. Because of the weight of the battery, suspension parts had to be beefed up, additional weight, plus the weight of the electric motor. Taken together this is why the E53 is 20% heavier than the E450.
Of course you are being facetious: diesel will not be returning to the US anytime soon! You do not have to be driving 300/400 per day to make the E450 the economic choice over the E53. 40% of my driving is long distance, so the operational cost of the E450 because of the significant reduced cost on the open road vs. the E53, makes economic sense.
There is of course the acceleration difference between the E53 and the E450, which is significant. With the passage of the BBB, the Federal Tax Credit of $7,500 will soon be gone. That makes the price delta between the E53 and the E450 $18,000. To those who will buy the E53, that price delta is worth it. To most I suspect it will not be.
As to resale: only time will tell: if the complexity of the E53 being a PHEV proves troublesome, than after 5 years most of the $18,000 delta will disapear.
1 | Clarifying the Weight To clear up confusion, the certified curb weight for the U.S.-spec E53e is ~5,280 lbs (Motor Trend’s test vehicle was 5,309 lbs). While it’s heavier than initially quoted, the chassis engineering, including the low-mounted battery and rear-axle steering, significantly offsets this extra mass in real-world handling and braking performance.
2 | Hybrid Efficiency & Real-World Use Yes, the E53e provides around 40 miles of pure electric range, perfect for daily commuting. Even when the dash shows "0 miles" of EV range, about 30% battery capacity remains to maintain torque fill and consistent power delivery. On highway runs, the car achieves approximately 28 mpg—only a modest reduction compared to the E450, while city commuting frequently returns 55–60 MPGe.
3 | Practicality Despite the battery placement, trunk space remains practical and virtually identical to the previous W213 E53, easily accommodating two large suitcases and additional luggage.
4 | Cost & Value Proposition The real price difference between the E450 and similarly-equipped E53e is closer to $10,000, accounting for features unique to the E53e such as AMG Ride Control, performance brakes, and rear-axle steering. Factor in the running costs savings with frequent electric use, and the overall value becomes even more attractive.
5 | Long-Term Reliability Hybrid components carry an 8-year/100,000-mile warranty, and the advanced battery management technology ensures robust long-term reliability and performance.
Bottom Line: If long daily highway drives dominate your use case, the E450 might be the practical pick. However, if you value the blend of AMG performance, refined driving dynamics, and electric versatility for daily commuting, the E53e offers an unmatched combination in the current market.
Cheers
My E53 weight is 2435kg on COC Certificate Of Conformity on official ownership documents.
I use my car for my job and so I can drive weekly 500 to 1000 miles and my average consomption is around 7,5-8,5 l/100km, using manual gear on highway to force 8-9 and refill battery each night at the hotel for 70-90km electric range. May be less than 450 and 1 liter more than my previous BMW 30d and 0,5l more than 545e (which was incredibly efficient).
@JTK44 if there was no « tax punishment » on ICE and powerful motors in Europe and in France particularly, I should have keep on driving inline 6 cylinders diesel with more than 250-300HP and 620Nm of torque.
But high power 400-500HP Hybrid PHEV give so much more pleasure to drive that it makes worth this pricey choice for a company car as mine’s.
@E53DadWagon wrote it, there is no choice in wagon, AMG E53 or BMW 550e less sporty… and in sedan, E450 and E400e.
New Audi S6 and Panamera Hybrid doesn’t propose the same things
Personally, when I order my next E450 I do not want nor would I pay extra for air suspension, rear wheel steering or performance brakes - more complicated and more prone to break. When it comes to either trade or sell, something that will happen to all of us, that $18,000 delta will probably shrink to less than $5,000.
Cheers
The below picture is of my 2025 E450 All-Terrain, which barely fits my dog crate in the hatch area. My 2022 E450 All-Terrain (subsequently sold to my brother) had an INCH of spare space above the crate, while in the 2025 version, the top of the crate is brushing the top of the hatch area, which is why it has those 2 yellow towels placed there.
You try to fit the same crate into the E53 wagon, with several INCHES of less height in the hatch area, and you will be a seriously disappointed customer, since you will NOT be able to do so. I will take the extra cladding, for the MUCH more usable product. Killing the space in the hatch area, is the LAST thing I need, as a wagon customer.
God, I would have paid 5K$ MORE, if they offered an E53 wagon, without the PHEV stuff that's mandatorily tacked onto it. And my sincere hope is that if an S214 E63 wagon appears, it will not have the PHEV tacked onto it, and will be a pure performance product. But going by trends, with the BMW M5 being a PHEV product, I think MB will also succumb and come out with a 5500lbs PHEV porker.
1 | Weight & Handling:
The claim of nearly "1,000 lbs of dead weight" is misleading. While the E53 is indeed heavier than the E450, the approximately 800 lbs difference is strategically placed low and centrally, significantly improving the car’s balance and stability. With advanced AMG Ride Control adaptive suspension, rear-axle steering, and robust braking systems, the car's real-world handling remains exceptional and has been independently verified through tests by Motor Trend and other reputable sources.
2 | Hybrid Efficiency & Practicality:
The battery never becomes mere "dead weight". Even after indicating "0 miles" EV range, around 30% reserve battery capacity remains to maintain consistent hybrid torque and performance. This is not theoretical but a reality that ensures seamless performance without noticeable drop-off. City commuting efficiency typically achieves 55–60 MPGe, and highway performance remains highly competitive at approximately 28 mpg—hardly a "substantial penalty" compared to the E450’s slightly higher mileage.
3 | Cost & Value Clarification:
JTK44 frequently mentions an exaggerated $18,000 price differential. When comparing similarly equipped models accurately, the real-world cost difference is closer to $10,000. The E53 includes substantial standard performance upgrades (AMG suspension, performance brakes, and rear-wheel steering) that significantly narrow this price gap. Factor in operational savings from frequent electric use, and the value proposition clearly favors the E53 for those seeking more than mere economic commuting.
4 | Reliability & Complexity:
Concerns about complexity are understandable but not borne out by real-world data. AMG hybrid components benefit from extensive testing and engineering derived from hypercar-level technology and come with a substantial 8-year/100,000-mile warranty. The proven reliability and advanced battery management significantly mitigate any real-world maintenance risks.
Bottom Line:
While the E53 isn’t designed to be the ultimate budget commuter, it excels as a versatile and dynamic daily driver, offering unmatched AMG performance, advanced technology, and genuine practicality. After extensive personal use, I confidently confirm it surpasses expectations across multiple criteria without compromise or regret.
Contrary to what was implied, the battery’s placement is deliberate and purposeful, optimized by AMG engineers precisely to maximize handling performance and minimize any negative effects of additional mass. The E53’s agile handling and stability have been repeatedly confirmed in real-world tests and reviews, including by reputable sources such as Motor Trend.
Let's stick to factual accuracy here—misrepresentations do no favors to anyone genuinely interested in understanding these vehicles.
What you're seeing there is exactly what I described earlier: The battery in the E53 is not "just thrown into the trunk" as dead weight. It's placed deliberately low, directly ahead of the rear axle, precisely to optimize the vehicle's center of gravity and maintain ideal weight distribution. This strategic placement significantly contributes to the car’s agile handling and balanced dynamics.
AMG engineers aren’t amateurs; the battery positioning shown in your own image clearly demonstrates their thoughtful approach. It ensures stability and performance—exactly the opposite of what you were implying.
As I posted the law of physics apply - even to Mercedes: It is not possible to have two identical cars except for the addition 800 lbs sitting over the rear axle ride, handle, turn and stop the same unless you are willing to spend thousands of dollars extra!
If you follow Tesla, Musk spent billions to make each Tesla as light as possible. Mercedes and every car manufacturer does the same: to make the car as light as possible. With The E53 Mercedes has gone in the opposite direction.
If you go to my post #238 you will see how a hybrid is used for extra performance at a minimum additional weight.
The extra weight there was about 200 lbs. not 800 lbs.
I think everyone can agree that the more complex a car is, the less reliable it is. Adding complexity means more things to break!
As to hypercar-level technology, again check out post #238 to see how electricity is properly added..
There is an old adage:
With the E53 and the first time for Mercedes, a brand new PHEV drivetrain, buying the first year of production, where not thousands but perhaps hundreds are made, thinking that everything will be fine is a fantasy.
It’s your opinion, you own and drove an « old » E450, your use of your car needs some advantages and characteristics that E53 don’t have, you do not appreciate some equipments that may offer comfort, ease of use and excellence or luxury from S Class, it’s your right….
But please stop E53 bashing even some facts are real and some of your conclusions are founded. …L1Wolf
You are happy with your 2019 E450, let us be happy here with our 2024 E53 or 2025 and explain why for potential buyers and mostly satisfied owners
The Owners of this E53 are conscious of the pros and cons of this hybrid car, but the balance (and financial capacity) are OK, and we bought it.
it’s not the best car (none is but one may match most needs and dreams of its owners), but it’s a good one.
You are happy with 375 HP, let us enjoy the 20% extra-weight and the 35% of extra-power and extra-torque… and the 40 miles of electric range, 10% of total range
For me, less is not more,
NB: try a current top ICE E450 or a 2021 BMW 545e or a 2024 BMW 550e and you may change your point of view on weight, consomption and driving !
