E-Class (W214) 2024 -
E/W214: E53 brake pad & rotor wear after 9700 miles
Old Jun 13, 2025 | 08:28 PM
LAZARU5's Avatar
2025 E53 Hybrid
I removed the wheels today to do a thorough cleaning job. While the wheels were off I inspected the brake pads and rotors. After nearly 10K miles both the front and rear rotors are only worn about 0.1mm. There is barely a ridge on the edge of the rotors. At this rate, the rotors will last over 100K miles. The front pads are down to 11mm and the rear pads are at 9.5mm The pads will also make it to 100K miles, but the sensors will probably be triggered between 80K and 90K miles.
Old Jun 13, 2025 | 09:23 PM
TulsaVic's Avatar
2025 S580
Speaking of brakes (and the E450 in particular), does the cruise control use brakes to control the car's speed? I know it uses battery charging, but at some point are the brakes used. My V90 Volvo used the rear brakes (no charging) which caused a very noticeable brake pad wear for the rear wheels.
Old Jun 13, 2025 | 09:24 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
My 2025 E450 had the first service done at 9,744 miles and front and rear brake pads were measured at 10mm. The mild-hybrid models also have regenerative braking and I expect them to do well on brake wear as well. Maybe even better due less weight. I'm not sure if it will last 100K miles though. I guess we will have to wait and see.
How do you know your rotors have worn 0.1mm? Did you measure them new?
Old Jun 13, 2025 | 09:27 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
Yes, it will use the brake system to slow the car at cruse control such as when going down hill or if you change the set speed to a lower speed. When it does use the brakes I assume it still uses the regenerative braking just as it does when you apply the brakes yourself. Obviously if you hit the brakes hard the brake pads will engage too, but I would imagine the minor adjustments made during cruse control operations may not ever engage the brake pads.
Old Jun 13, 2025 | 09:54 PM
LAZARU5's Avatar
2025 E53 Hybrid
Yes. the base front brakes (370mm rotor) are 36mm and the rears are 26mm. Minimum thickness printed on the rotors is 34/24 for front/rear rotors.
I suspect that the 10mm measurement provided by your dealer is an eye-balled nominal measurement, not an actual one. The initial thickness for the front is 12mm and the rear is 10mm. It's unlikely that your front pads wore down 2mm while your rear pads did not wear down at all. It's interesting to note that new rear pads on my EQS SUV were just under 8mm thick. The W214 pads are probably shared with other MB ICE vehicles so MB did not use thinner pads like they do on a BEV. These measurements are probably not relevant to an E350 with smaller brakes.
Old Jun 13, 2025 | 10:02 PM
LAZARU5's Avatar
2025 E53 Hybrid
Like @L1Wolf , I doubt if the Distronic cruise control will use the friction brakes unless traffic in front of you comes to a complete stop. However, if you toggle on Lane Keep Assist (LKA) then you will see brake dust on rear wheels and the pads and rotors will need to be replaced more often than every 100K miles. I don't think LKA can use recuperative braking since it cannot be applied to one rear wheel at a time in order to shift the car over in the lane.
Old Jun 13, 2025 | 10:56 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
I have adaptive cruise control on my E450: When it senses a car in front and needs to slow down I notice the rear brake light in the rear window. So "yes" on my E450 brakes are used to control speed when I use cruise contro;/
Old Jun 13, 2025 | 11:13 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
In the inspection video they provided the tech used a feeler gauge on each wheel to show what the brake wear is.
Old Jun 18, 2025 | 07:57 PM
Huleyman's Avatar
E53 (2025), C300 4MATIC (2014)
Maybe related, but only at 300 miles...
My 2025 E53 wheels or brakes were humming at a cadence that matched the speed I was going. Whoosh, whoosh, whoosh was ever-so-slightly heard echoing off nearby curbs/barriers and it was clearly coming from the wheels or brakes on both sides of the car. Brought it in for inspection and the head technician went for a test with me and agreed it was likely the brakes. They've done some stuff, but it still happens when they test so they may replace the brakes. While sanity checking they've now noticed other W214's at the dealership will also do this. They didn't specify whether those W214's were E53's with the Dynamics package (390mm front discs). Stay tuned for the outcome.
Old Jun 23, 2025 | 12:53 AM
Huleyman's Avatar
UPDATE: After inspections, tests with other E53's and other W214's, and coordination with Germany later, it seems like the coating on the brakes is "part" of the noise and will subside after 700-1000 miles (I'm only at 300). All that investigation was complimentary as they also thought is sounded a bit weird and encourage me to return at 1000 miles.
Side story: Turns out the OEM MB dash cam (which turns on automatically) showed 2 days of inspections (inside their garage), tests in the parking lot and on local roads, more inspections and tests. I even saw some of the other W214's they tested. Impressed with how thorough it all was. Only downside to checking footage: I asked them to NOT WASH it as they use a touch washer with brushes. You guessed it. The person transporting from their offsite garage to the dealer ignored the "NO WASH" sheet the service manager put on the seat and ran it through the onsite touch washer. For most people this is probably a bonus. For an uptight AMG owner like me I was sad. My paint will live, I got over it.
