E-Class (W214) 2024 -
E/W214: Map Update V13.0 is out
Old Jul 21, 2025 | 01:00 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
Looks like map version 13.0 is available. I'm downloading it now and will install it in the morning.
Old Jul 21, 2025 | 08:13 AM
estark's Avatar
2025 E450 Sedan: 2019 E450 Coupe
I already installed it, no issues... Did you get a notification that it was available? I still have never received any notification that a new version was released. My other car (2019 E450 Coupe) I receive an email when a new map version is released and an OTA update. I download it for that car also to get a full update.
Old Jul 21, 2025 | 08:55 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
No notification. I just check every now and again. Last time I checked was about 3 weeks ago and it was still V12.0.
Old Jul 21, 2025 | 05:48 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
My map update was done without an issue. I hooked the car up to a battery tender while I performed the update in my garage and the ignition on, but engine not running. Took about 30 minutes total.
Old Jul 30, 2025 | 10:13 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I've been unsuccessful with v12 and v13. Can the successful installers share the details?
I'm using a SanDisk formatted to ExFat. It's 128gb and named NO NAME by default. The download manager had no errors, successfully download the v13 update. I insert the thumb drive in the center console, nothing activates. Also bring up the settings via the navigation prompts that shows the old version is installed, but it doesn't trigger an update.
Old Jul 30, 2025 | 11:15 AM
estark's Avatar
When you insert the USB drive, go to settings, system and scroll down to software update and see if it shows up on the screen. Also, I previously found that if you only update your region, even though it may say that the update was installed, when you check the version number it will not change. Now I update the full map which is about 32GB. You might want to reformat the drive to NTFS, Since I have already updated mine, I can't check the format.
Old Jul 30, 2025 | 11:39 AM
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
Are you using a Mac? I initially had an issue after reformatting a disk to ExFat. The part of the Disk that held the map files was ExFat and when I inserted it into the car, nothing happened. I put it back into the Mac and went to Disk Utility and saw that the top line* for the disk was Mac OS Journaled or something. So I re-formatted the disk so that both lines* were ExFat. That solved my problem. When I inserted the newly formatted disk, it fired right up and installed the maps.
*pardon my wrong terminology but hopefully you can understand what I'm talking about
Old Jul 30, 2025 | 01:27 PM
kjb55's Avatar
Thanks everyone. Yes, using a Mac and know exactly what you're describing. Mac also didn't have NTFS as an option. Since I have access to a PC - I erased and reformatted the drive to ExFat and am doing the update via the PC. Not saying the Mac wouldn't work, but mine as well try the PC. The car is not a daily driver but I'll try and stop by storage garage and try it in the coming days.
Old Aug 4, 2025 | 05:10 PM
kjb55's Avatar
Success updating to v.13. Definitely just a USB stick formatting issue on my part. Thanks for the fix.
