Tire Size Help - 2025 E450
Have a brand new E450 with the 19” wheels.
Current tire size is staggered:
245/45/19
275/40/19
Looking to go same size all around for winter tires. Dealer says rear wheels are too wide to run 245 but 255 is minimum. Can I run 255/40/19 on all four without rubbing in the front?
My wheel specs shown below.
For more info check 255/40 R19 tire on a 19x9.5 rim. There are some performance issues.
For people looking at the E53, the winter wheel and tire package for the E53 is the same size.
My tire guy told me some Mercedes have issues with the traction control computer throwing codes on a square setup. I changed to BBS wheels in a square setup, and the tire installers insisted on staggering the tires. It seems weird to me, but it seems to work.
Question: I presume my stock staggered size will work equally well if I drop to a 35R all around? Shouldn’t be a problem?
245/35/19
275/35/19
I have an opportunity to get some Conti Winters for a very good price.
245/35/19
275/35/19
Curious why you are so eager to get different sizes for winter? You can get the exact sizes you have now in all seasons or winter tires. You know that it works. What problem are you trying to solve here?
BTW: I thought your car came with 18" wheels based on this post. I'm confused after looking at your profile and other posts. Do you have a 2024 E350, 2025 E450, a 2025 E350, something else? Not that it matters, but if you are asking for advice it should be based on correct information.
