E-Class (W214) 2024 -
E53 brake noise
Old Jan 24, 2026 | 03:35 PM
E53DadWagon's Avatar
2026 E53 wagon
E53 brake noise
Hi all. Nearly new E 53 with the enhanced brakes with the red calipers and it just started making a truly horrific squealing noise when coming to a stop at low speeds. Does not do it if you slam on the brakes. Only seems to do it when you come to a normal, slow, stop. Is this common? Will it go away on its own? It seems to have started after the car sat unused for about 2 weeks. Thanks!
Old Jan 24, 2026 | 05:32 PM
wdimagineer's Avatar
E 53 Wagon
It's common. Both of mine have done it, at lower speeds. The squeaking tends to go away when the discs are warmer. I've found bedding them with firmer braking from speed helps to alleviate it.
Old Jan 24, 2026 | 06:35 PM
geektoad's Avatar
26 E53 Wagon
Mine squeak as I'm pulling out of the garage and up to the the stop at the end of my road. I hadn't thought much about it, as it's common for performance brake pads to squeak a bit until they're warmed up. If you're hearing it more that at the very beginning of a drive, it makes me wonder what effect the regenerative brakes are having an effect on letting the physical pads drop below operating temperature.
Old Jan 24, 2026 | 07:48 PM
Huleyman's Avatar
E53 (2025), C300 4MATIC (2014)
In my second week of owning my E53 I brought it back to the service dept for this. The head tech drove with me (windows open) and said it shouldn't sound like that. Then for 3 days (I have it all on dashcam) they proceeded to drive, adjust, drive, and then test other E53s (I saw them drive them past mine via dashcam) and talk to Germany - all this to eventually determine what others have said above. I'm at about 900 miles now (with some aggressive braking about 10 times inside that) and don't hear much of a peep out of those brakes now. No permanent adjustment was made (Germany told them to reset after their changes). This is how long the performance brakes take to settle in.
Old Jan 25, 2026 | 12:26 PM
Avi8tor's Avatar
AMG E53 214.063; BMW IXM
This sounds like the classic AMG “high-performance brake squeal” + light-use/regen combo, not necessarily a defect.
On the W214 E53, the “enhanced brakes with red calipers” are the AMG high‑performance compound/composite setup (aggressive pad compound + 2‑piece steel/compound rotors) — not carbon‑ceramic rotors. Those pads are built to handle high temps/loads, but the tradeoff is they can be noisy when they’re cold and/or when you’re using very light pedal pressure right as you roll to a stop.
Two things make it worse on the E53:
1) It’s a plug‑in hybrid, so a lot of normal decel is handled by recuperation (regen). That means the friction brakes can stay cooler and see less “work.”
2) If the car is driven gently, the pad/rotor interface can end up with an uneven transfer film or a lightly “glazed” pad surface. That creates frictional vibration (squeal), especially at low speed and light brake pressure.
Mercedes actually has internal guidance acknowledging AMG brakes can make noises under certain operating conditions (speed/brake pressure/temperature/humidity). So some level of squeal can be a “characteristic,” not automatically a failure.
What usually helps:
- Make sure it’s not something physical (small stone, bent dust shield, etc.)
- Re-bed / deglaze them: in a safe, empty area do a series of medium‑firm decels (NOT panic stops / not ABS), then drive a few minutes with minimal braking to cool. This re-establishes an even transfer layer.
- Avoid sitting stopped with hard pedal pressure immediately after heavy braking (can imprint material and worsen noise).
If it’s truly “horrific,” persists when fully warm, or you feel vibration/pulsation, have the dealer inspect. There are specific dealer-level fixes (pad chamfer/contact-point treatment + formal bedding procedure) if it’s beyond normal.
Old Jan 26, 2026 | 07:22 PM
shakoomakoo's Avatar
2025 E53 AMG & 2024 EQS SUV
No break noise what so ever on my E53 sedan. I do a lot of highway and I wonder if that helps reduce this as I break from high speed most of the time.
Old Jan 26, 2026 | 08:50 PM
2026 E53 wagon
are you somewhere cold?
Old Jan 26, 2026 | 09:19 PM
Kansas City.
Old Jan 27, 2026 | 02:21 PM
LAZARU5's Avatar
2025 E53 Hybrid
I have not experienced any brake squealing after 22K miles with base W214 E53 brakes (silver calipers).
Old Feb 2, 2026 | 11:39 AM
Rick_H's Avatar
2025 E53
I'm taking mine in next week for it's one year service. I have 8,000 miles on it and my brakes have been screaming since day one! It's embarrassing when people look whose brakes are screaming and they see a gorgeous car, expecting to see something much different
Old Feb 2, 2026 | 01:00 PM
2026 E53 wagon
Originally Posted by Rick_H
I'm taking mine in next week for it's one year service. I have 8,000 miles on it and my brakes have been screaming since day one! It's embarrassing when people look whose breaks are screaming and they see a gorgeous car, expecting to see something much different
had same thing happen yesterday lol.
Old Feb 2, 2026 | 04:16 PM
Mercuccio's Avatar
I have the Dynamics package with AMG brake squeal. The car has about 500 miles on the car. I first noticed it in the recent cold weather and when slowly coming to a stop.
There is a TSB which says the solution is to apply heaving braking just below the threshold of ABS. My car hasn't passed the break-in period yet so I'm going to wait before getting some speed and doing some threshold braking.
Now when we come to a stop, my whole family makes the noise, "SQWEEEEEEEEEEK!" Then we all ask ourselves if that was annoying. It takes the edge off if you make a game of AMG brake squeal. In addition, multiple humans saying "SQWEEEEEEK!" loudly in unison drowns out the much more grading actual AMG brake squeal.
Old Feb 2, 2026 | 04:22 PM
Mercuccio's Avatar
What usually helps:
Thanks for the write-up.
Is the formal bedding procedure doing threshold braking just below ABS kick-in? I think "panic stops" below ABS kick-in is one officially approved method the service technicians are given to fix the issue. My local sales manager says he has gone on a few of those rides.
Old Feb 3, 2026 | 10:55 AM
geektoad's Avatar
26 E53 Wagon
I don't know if it's "formal" but yes, 3-5 hard stops just under ABS from 50-55 to stop, then driving gently for 10 minutes to let them cool is how i've bedded performance/race compound brake pads for 30 years. It works.
Old Feb 3, 2026 | 11:28 AM
Richbot's Avatar
'26 E53 | '08 E90M
Our 212 AMG did this too when cold.
When I hear brake squeal on a nice car I think "oh somebody actually has performance pads in their performance car"
Lions do not concern themselves with the opinions of people who only brake hard when they look up from their phone too late
Old Feb 8, 2026 | 03:04 AM
Mercuccio's Avatar
Once it warmed up to 30 degrees my brake squeal went away. They were squealing away at 9 degrees F.
