W214 E53 camber adjusted to reduce inner edge rear tire wear
A wheel alignment in December indicated that the rear camber was within factory specs, but rear toe-in was slightly out of spec. If I had known that the rear camber could be adjusted, I would have requested that the negative camber be decreased and set to the opposite end of the factory specified range. But, since the rear camber was just barely within spec, only the toe-in was adjusted.
Adjusting the rear camber requires removing and replacing a one-time use bolt that attaches the rear spring link to the chassis through obround holes in the spring link. Before re-tightening the new bolt, and after removing a spacer used during the factory assembly of the car, the camber adjustment bolt can be used to set the rear camber. The exhaust system must be lowered in order to pull the long bolt rearward. The dealer tech reversed the direction of the newly installed bolt to facilitate its removal in the future without lowering the exhaust system.
The green spacer which was removed and discarded is 7.5mm thick. The clearance between the spring link and the steel bracket was reduced to about 3.5mm after the negative camber was adjusted to -1º41’.
I will have to drive 5K to 10K miles before checking to see if the decreased rear camber eliminates or at least minimizes inner edge rear tire wear.
Rear suspension before camber adjustment.
Rear suspension after camber adjustment.
Spring link position before camber adjustment.
Spring link position after camber adjustment.
One time use nuts and bolts and production line assembly spacers.
Is this an E53 sedan or wagon?
Did the dealership make these changes or did they just assist with a few things and you did the camber change yourself?
Thanks in advance...
The dealer did the work. Initially, the SA and tech tried to talk me out of doing the camber adjustment and just accept the excessive inner tire wear as normal for an AMG car. But, then they acquiesced and the tech was enthusiastic about the project since he had not done this job on the W214 chassis previously.
This is not really a DIY job. The long one-time use bolt that secures the spring link to the chassis is tightened using a two-stage torque procedure. First it is torqued to a specified amount and then it is turned a specified number of degrees further stretching the bolt. It would be possible to replace the bolt with the car on jack stands or a residential lift and do an "approximate" alignment. But, if you fully tighten the bolt before taking the car for an alignment, the bolt would have to be replaced again if the negative camber was not exactly the angle you wanted.
The only thing I did myself was to remove the rear tire and take some before and after photos.
I suspect that once some independent shops realize that the rear camber can be changed they may make an adjustment and reuse the bolt if they are unaware (or don't care) that it is a one-time use bolt.
The camber adjustment bolt can be turned clockwise to pull the spring link inwards to reduce negative camber. As far as I can tell, the weight of the car is what "pushes" the spring link outward to increase negative camber when the camber adjustment bolt is turned counterclockwise.
Camber tire wear on AMGs is real. I prefer the more neutral handling on AMGs, but they do go through tires.
Not a normal way but none the less it can be adjusted.
Good for you to get this done and let others know.
May the tire gods be good to you and long live your rears!
