E450 Auto Start Stop
Considering moving from a BMW G60 540i and before that a G30 to a E450 later this year. Looking forward building out a luxurious interior after the somewhat austere bimmers. Is it possible to turn auto start stop off permanently? If not, assuming I use the default drive mode and don't change to sport each time, is it one button each time you start the car? Do you have to go through screens or is it a hard button?
It also occasionally turns off the engine as I’m pulling into a parking brake which results in the car slowing then lurching forward a few inches as it restarts the engine.
As the W214 first does regen brake before physical brakes, if I recalled correctly, it does physical brake and regen brakes regardless at gear 1,2,3 etc. When it does regen brake at say higher gear, gear 7, you will notice the "charge" bar is at max.
Some MB models you can program the car to send a message on the MBUX screen to tap to disable stop start. If you do not have that option you can create a routine.
Of course it is, but didn't want to go there as many think start/stop is a political issue.
I recommend going the coding route instead.
