Belt Wrap Kit for Supercharged M113 motors
#129
Just wanted to let everyone know, that last year, after I installed the Belt Wrap Kit with the perfect sized belt for my car, my boost went up from 15.5-16.0 to 17.5-18.0 PSI. This kit really helps and I have absolute no belt slip whatsoever!
Thanks Shardul!
Thanks Shardul!
#139
My install is done. I never thought it was going to be that time consuming. My torx bits were too long and I didnt remove the fan shroud so I had some problems.
The belts were really hard to put on even when the tensioner was pushed all the way back.
#140
PLATINUM SPONSOR
Fan shroud removal takes a few minues and then it is easy to tighten bolts and put belts on. Great mod and you will feel the full range of boost now.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#141
2003 E55 AMG
#143
2005 E55 AMG, 2000 Viper GTS (head,cam, supercharged), 2014 Mazda 3 (daily), 2004 F150, Harley& Busa
Hi please shoot me a pm for a delivered price to 02421.
2005 e55 107,000 miles.
Will this work no problem with the pulley & tune kit sold by the other vendor on here?
#145
PLATINUM SPONSOR
Yes it will work with others tuen and pulley and you may also consider changing your idler pulley`s out at the same time, since you have 107K on the engine.
__________________
www.ultimatepd.com
www.ultimatepd.com
#146
#147
Thanks for the video, it looks pretty easy to install.
3 questions:
- You mention torque wrench but no torque value is given
- The accessory belt, is that the same as the serpentine belt ?
- Do you ship to europe (France) ?
#149
E55 AMG 2003
Hi Shardul, is the kit still available? And are you sellingthe Belt wrap kit, 3 piece ASP idler pulley and smaller s/c pulley all together?Please send me the prices.
#150
2003 E55 AMG
