FS: Carsoft v7.4 multiplexer scanner / diagnostics
Old Jul 3, 2008 | 04:35 PM
AMGDave's Avatar
300D, 500E, E420
Hi folks,
This is a multiplexer unit that works with Carsoft diagnostic software v7.4, and your Windows PC. The PC you use must have a 9-pin serial (COM) port. I'm not sure what the OS requirements are, but it works fine on my laptop with Windows XP SP2. I ended up with two of these systems (long story) and don't need the extra. I tested the software, multiplexer, and 38-pin cable and they work fine. (I don't have vehicles available to test the other cables.) I believe this system works on vehicles through 2003. (?) Here's what you get:
  • Multiplexer interface box, "all K-lines wired"
  • 38-pin interface cable
  • 16-pin OBD-2 interface cable
  • 14-pin Sprinter interface cable
  • Cable for older 8- and 16-pin vehicles (late 80's, early 90's)
  • Serial cable to PC
  • Carsoft software v7.4
$160, free shipping in the USA. See photo below.
Attached Thumbnails FS: Carsoft v7.4 multiplexer scanner / diagnostics-multiplex2_06.jpg
Old Jul 14, 2008 | 10:01 PM
AMGDave's Avatar
300D, 500E, E420
Bump...
Old Jul 26, 2008 | 04:55 PM
gregory13lil's Avatar
2000 CLK430
Dibs if this system will allow me to reset the EC light on my air conditioner control module on my 2000 CLK 430.
And will this let me look at all the codes instead of going to the stealership? If not then what does it not check? ie..trans, ac???
These might be dumb questions but I have never bought or seen these systems in person so I am not aware of all it can do.
Thanks,
Greg
Old Jul 26, 2008 | 08:04 PM
AMGDave's Avatar
300D, 500E, E420
Hi Greg,
I believe it will do what you want for your 2000 model year car. My car is a 1994, and is OBD1 (sort of), not OBD2. The setup has pretty limited functionality on my old car, but for your CLK, it will show error codes, allow you to re-set them, do coding & adaptation, and also show live data with the engine running. But I haven't been able to try some of this stuff since it's not applicable to my car (I can only read & delete error codes).
I took some screen shots of the software, that will show you all the options available in the menu. I also took a couple of screen shots of what the error code display looks like. Click here to download the Zip file (1MB) with the pictures...
Old Jul 28, 2008 | 03:20 PM
AMGDave's Avatar
300D, 500E, E420
Here are a few sample screen shots:
Old Jul 30, 2008 | 04:18 PM
2000 CLK430
Thanks for the screenshots. I am going to pass on this until I get more info on the new one that is V2.
Greg
Old Jul 30, 2008 | 04:23 PM
AMGDave's Avatar
300D, 500E, E420
No worries, Greg. What is "V2", btw...?
Old Jul 31, 2008 | 10:50 AM
qianlimoro's Avatar
fleet vehicle
Originally Posted by AMGDave
...it will show error codes, allow you to re-set them, do coding & adaptation...
So you could really screw things up if you weren't careful I suspect...
I'm not sure I could trust myself....
Old Jul 31, 2008 | 11:06 AM
AMGDave's Avatar
300D, 500E, E420
LOL!
It does adaptation erase, which I believe re-sets certain modules back to factory defaults, which shouldn't cause any problems.
The coding is for certain modules from roughly 1995/96-up, where they had to be VIN coded to match the vehicle. This software will "read" the coding on the existing module, then "write" it to the new module you're installing.
Neither applies to my W124, which is why I'm selling it...
Old Aug 8, 2008 | 12:12 AM
Thunderdome66's Avatar
99 CLK 430, 84 v8 rx7, 97 gtp grand prix
http://cgi.ebay.ca/Mercedes-Carsoft-...QQcmdZViewItem
is this not the same?
Old Aug 8, 2008 | 12:16 AM
AMGDave's Avatar
300D, 500E, E420
Originally Posted by Thunderdome66
Nope - not the same. The cheaper versions (<$100) like the auction above are not multiplexers. Note that the connection from the car to the black box in the cheap auction are only 15 pin, not 37 pin. The multiplexer has a 37-pin connection. The cheaper setup, when connected to the Mercedes 38-pin connector, will only "talk" to a few of the systems - not all of them. You'll notice that the auctions for the true multiplexer units will usually say "all K-lines wired", and those usually cost closer to $200 including S&H...
Old Aug 18, 2008 | 11:43 AM
AMGDave's Avatar
300D, 500E, E420
Sold - thanks for looking!
