JBSPEED/Velocity Adjustable Throttle Booster System
Old Sep 17, 2009 | 10:14 PM
JBSPEED's Avatar
SPONSOR
Lexus NX200T F-Sport AWD
Technical Specs
- 4 power profiles selection, adjustable according to different driving needs
- Optimized throttle characteristics to enable immediate throttle response to the engine in real-time, resulting in faster response
- Simple plug-and-play, with no modifications
- Slim and compact design
- Unit can be powered off during driving, and powered up as needed, anytime
- Intelligent, self learning feedback algorithm to enable optimized driving
- Comes with 1 year manufacture warranty from purchase date
Mercedes
C-class (all models up to W203)
E-Class (all models including the latest W211)
Old Sep 18, 2009 | 01:18 PM
JBSPEED's Avatar
SPONSOR
bump
Old Sep 18, 2009 | 01:20 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
give us something that eliminates shift adaptives and you won't be able to keep up with demand!
Old Sep 18, 2009 | 01:50 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
impossible, thats built into the tranny ECU, you can't eliminated that.
interesting design though, much better than sprint booster it appears. not bad.
Old Sep 26, 2009 | 02:38 AM
nismoy33's Avatar
04 E500
how much?
Old Sep 26, 2009 | 02:47 PM
tazim's Avatar
2015 E550 W207
Originally Posted by nismoy33
how much?
+1
Old Sep 26, 2009 | 05:44 PM
advans's Avatar
C55 ///AMG, 535xi
so is this thing generic? or car specific, i'm interested in one, for my AMG
Old Sep 26, 2009 | 06:28 PM
Tump43's Avatar
2014 E350 4Matic
Please pm me the price, install instructions, and expected changes over the sprint booster for a 2005 C55.
Old Sep 30, 2009 | 01:41 PM
jokerswld34's Avatar
05 c230 kompressor SS 6MT & 07 BMW 335i
i would love some data and pricing for my 6mt c203 SS . i have sprintbooster and powerchip software; what will my experience be over the booster?
Old Sep 30, 2009 | 05:45 PM
BigBodyBenzC240's Avatar
...a panty dropper...
Would this really show any type of gain since I already have the sprintbooster? Does this add hp or is it just like the SB and makes the acceleration faster to make you think you gained more power? Price and description requested, thanks.
Old Sep 30, 2009 | 09:04 PM
bdragomir's Avatar
2004 E55 & 2004 E500 (W211)
how much?
would this work on a '98 C280 sport? $?
Old Oct 1, 2009 | 12:09 AM
AMG
It appears this is an adjustable sprint booster so you can dial in just how snappy the throttle response would be. It appears it is also universal (which isn't necessarily a bad thing). Never seen one of these actually installed though. I am curious to see what other possible models it could be applied to (W208, W209, R171 etc).
Old Oct 1, 2009 | 12:48 AM
bdragomir's Avatar
how much does it cost? and how do I pay if decide to buy it?
Old Oct 2, 2009 | 01:51 AM
JBSPEED's Avatar
SPONSOR
Thanks for the order!!
Old Oct 3, 2009 | 03:41 PM
JBSPEED's Avatar
SPONSOR
bump
Old Oct 5, 2009 | 12:04 PM
JBSPEED's Avatar
SPONSOR
bump
Old Oct 6, 2009 | 11:14 AM
SSM AMG's Avatar
2004 S55 AMG
Originally Posted by JBSPEED
bump
Can you answer in post the questions some of the members had about the product? I think it would sell the item better.
Old Oct 6, 2009 | 11:39 AM
JBSPEED's Avatar
SPONSOR
i will have a member write up everything when he gets his and installs.
Old Oct 6, 2009 | 11:41 AM
Bollywood's Avatar
2003 CL55
How universal is this product, as in, can it be applied to other brand of cars?
Old Oct 7, 2009 | 04:20 PM
pugguy2001's Avatar
2016 C63s AMG
I ordered one from JB Speed, so as soon as I get it and install it I will give my feedback. I will be able to compare it to the Sprint Booster, which I have had in my car for 4 years, with no issues.
Old Oct 7, 2009 | 04:28 PM
Are you going to remove your SB and install this or use them both running together? If your going to do a write up you should try it both ways for some of us who already have the SB like you do. Just my 2 cents.
On a different note, JBSPEED how come you havent wrote back to my question?
Old Oct 7, 2009 | 05:21 PM
pugguy2001's Avatar
2016 C63s AMG
The sprintbooster has to be removed, they connect to the same wire under the gas pedal. Its either the SB or Velocity.
Ill do my best with the review , but i am tired of reading the negative comments from the people who havent even tried the SB. Its easy to make a comment, but its not a comment that other members want to hear, its a first hand review that will make other members decide if they want it or not.
Old Oct 7, 2009 | 05:48 PM
hyper_tune77's Avatar
2006 mercedes benz C180k Avantgarde SE
How much is this Velocity cost?
Zack
Old Oct 7, 2009 | 08:54 PM
JBSPEED's Avatar
SPONSOR
Technical Specs
Mercedes
Installation –
I got home with high expectations of what this thing was going to do for me.
I grabbed a pick tool too to pry the cover off of the 5mm hex bolt.
Pull the bolt, and popped the accelerator pedal out within seconds
i popped the cable loose and connected the leading wire connector for the Velocity to the accelerator assembly
I connected the trailing wire to the car side of the wiring
I put things back in, in the reverse order of disassembly.
I found some body molding tape in the tool box. Took one strip of this stuff to make it nice and solid. 3M tape rocks! Cause it’s from Minnesota.
I think this install took ten minutes due to it being my first time pulling things apart in here and the fact I took a few pics for you guys.
I didn’t tuck wires inside panels, as I’ll need to take this out in the next few weeks because I’m taking my car in for service. When I get the car back I’ll take a few minutes to hide the wires
First thoughts –
No check engine lights or sprint booster blues running conditions that I’ve read about on this forum
In fact, nothing at all. Seemed like there was nothing new. The unit was off. I pressed the power button to be pleasantly surprised that the accelerator was very slightly different.
I needed more. By going to level 2 there seemed to be no lag in the pedal. Nice. I think this will be a great everyday mode for me.
Level three seems the most like a Sprintbooster. Like it’s amplified slightly. Good stuff.
Level 4 is crack cocaine mode. It’s kind of nuts. The car is a monster. And I totally forgot to put my car into sport mode until this point. Slide it over to sport and I’m starting to think The Tire Rack must be giving kick-backs to Velocity cause this is thing is going to be the demise of quite a few sets of tires I’m sure.
Old Oct 7, 2009 | 11:41 PM
stallion8797's Avatar
and how much?
