F.S. 190e 16v LSD 3.27
Old Jul 2, 2010 | 10:53 PM
money-one's Avatar
C43/2jz, Ml63, C32
I am selling my custom made LSD retrofited to fit in my 98 C43 and 99 C230 w202. This fits in other cars 124,170,210,201,202 but requires some minor changes. It is the whole assembly with a 3.27 gear ratio. It has seen better days but rest assured it works. Ill post a vid if it helps it sell. $320 plus shipping. PM address for full price.
Build thread
https://mbworld.org/forums/c36-amg-c...43-almost.html
Old Jul 12, 2010 | 09:02 AM
money-one's Avatar
C43/2jz, Ml63, C32
Revision to application list:
In its current state it will only fit the
w202 98-00 C230 kompressor
r170 98-00 SLK230 kompressor
With a swap of the flange on the diff housing with your original diff it will fit
w124 ? (for certain in a 300ce not sure on the rest)
w201
w202 93-97
With a center section swap from the lsd to a 124 housing with a 3.07 ratio it can be made to fit a
w210 E320
w208 CLK320
Old Sep 12, 2010 | 02:53 AM
jumph4x's Avatar
W210 DRFT BNZ
Still got it?
Old Sep 13, 2010 | 03:28 PM
money-one's Avatar
C43/2jz, Ml63, C32
Yep... Also has a fresh coat of low gloss black paint. Looks good.
Old Sep 13, 2010 | 03:40 PM
jumph4x's Avatar
W210 DRFT BNZ
Some natural questions:
  • I see it is made to fit a C36. I assume the C36 needs the flange mod?
  • What do you mean by 'seen better days'. Does it work as intended? Does it need new friction plates?
Let me know.
Old Sep 13, 2010 | 06:49 PM
money-one's Avatar
C43/2jz, Ml63, C32
When I said "seen better days" I meant the housing looked good at some point in it's life. The LSD was functioning when I removed it for packaging. This is what it looks like now
The flange does not look like it has to be replaced. There are 2 part numbers for the rear flex-disc
210-410-08-15
170-410-00-15
These appear to apply to you and the C230k which this was last on. I do have the other flange too. If you don't want to disassemble the original.
Old Sep 13, 2010 | 11:39 PM
jumph4x's Avatar
W210 DRFT BNZ
Wow, cool, so I wouldn't need to change anything? Direct bolt on?
Could you quote price with shipping to 06117?
Old Sep 14, 2010 | 07:54 PM
money-one's Avatar
C43/2jz, Ml63, C32
Pm sent
Old Sep 14, 2010 | 11:21 PM
money-one's Avatar
C43/2jz, Ml63, C32
Sold
