FS: 82mm Mercedes Throttle body
PLATINUM SPONSOR
This is the best TB period for the E55 and 55 S/C motor! There are no wire swaps are other modifications needed to be made like on other 82mm kits..
I took the pic next to a stock 74mm TB and you can see this is a plug and play TB and even the PCV hose on the bottom is the same.. This TB is also the stock lenght, so your airbox does not hit the firewall, like on some of the other 82mm being sold.. This is a rare TB to find and I also ported the shaft to add another 10% of air-flow.. This TB is in like new condition and only has about 3K miles on it..
I want 550.00 shipped to your door, anywhere in the mainland USA..
Back side or inlet side..
Shaft porting
Shaft porting
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
08 ML350, 2011 E550 Cab
So this will work for my SL55?
What kind of gains should i expect?
Lastly, i have done a little looking around, but not much research > are the only other things i need to make this work are a y splitter and have my SC inlet ported? Do i need an adaptor of some kind?
Nick
Nick
PLATINUM SPONSOR
Nick
Nick
You can port the stock inlet or buy the 80mm inlet and use it.. Either way, you will need a welded on adaptor or buy one of the machine adaptors made to fit.. I have a 80mm inlet, 82mm MB throttle body and a 82mm adaptor to mate them all together.. It is all plug and play and no codes..
Depending on mods, people post 20 plus rear wheel horse power gains.. I make 560 RWHP and my car is insanly fast on the street! All that power comes from 4 mods. Pulley, tune, 82mm TB and headers.. The other stuff , is icing for the cake..
__________________
www.ultimatepd.com
www.ultimatepd.com
So which is better to buy the 80mm inlet or have mine ported?? I have seen some side by side pics and it looks like the 80mm inlet is larger than the 74 (not the port but the entire assembly)???
Where can i buy an adaptor plate to weld on?
You wouldn't be interested in selling your inlet and adapter plate with the TB would you??
Nick
Nick
PLATINUM SPONSOR
Nick
Nick
80mm inlet is better.. IMO
Eurocharged has adaptor plates. Few other places listed on the forum, as I recall. If you buy the 80mm, you can have someone weld an adaptor on too. Lot of ways to go and you will save a ton of money..
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Thanks! A few people ready to send paypal for it but not sure who`s money will clear first.. These MB TB`s are hard to find and IMO, the best one for our car..
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Yes, it is for a 2009 550..
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
Getting a lot of PM`s but just wanted to let everyone know that this Mercedes 82mm TB is still up for grabs! Just enough time to get this installed and be ready for the cold air!
PLATINUM SPONSOR
Make me a GOOD offer !
__________________
www.ultimatepd.com
www.ultimatepd.com
1 Post
CLS 55 AMG, FX45, F-350, Top Secret Widebody Supra (Sold) and other vehicles on another Planet
I'm interested in this as well and need a bigger throttle body to complete everything I need to have Jerry tune my car here in Houston. Why are you selling if you don't mind me asking?
06 cls 55 amg
PLATINUM SPONSOR
JUST SOLD it!!!!!!!!]
__________________
www.ultimatepd.com
www.ultimatepd.com
c32 amg evosport stage 2
some one who have the partnumber
Do someone have the partnumber for sc inlet ? The 80 mm ?
What i have seen you get the y split from the airbox too from the tuners, is that one from a new sl 55 ? Some one who have the part number ?
Really thankful for help
I already have the 82 throttle body.
I need to buy the sc inlet
the y splitt and weld an adapterplate.
PLATINUM SPONSOR
mercedes e55 amg w211
