55k 190mm asp welded pulley
Good used pulley with zero wobble. Will make gobs of power. Pulley was 1500+ new. Willing to part with it 650+ shipping
PLATINUM SPONSOR
You have any pictures? Was this on your car and what mods do you have?
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
I'm going to double check the measurement after work as I was told it may be a 180. Let me verify this and I'll let you all know. Pulley measures right at 7.5 inches across but I want to double check so I'm not misleading anyone
